Thoughts on electric water pumps.......
All pumps are gallon per minuted rated. stock pumps actually have higher low rpm GPM because of their impellar design. High volume and aluminum racing pumps actually have tiny flow amounts untill higher rpm.
So your mech pump at idle might only be putting out a couple of GPM.
In a performance motor it will cause them to over heat if idled too long (stopped in traffic) That is where the electric shines. They run full blast at any rpm.
Ever have the problem of running around on a hot day and shut off your motor and thats when it begins to boil. That is where the electric shines again. I have a thermostat that runs the pump after my motor is off until the water temp goes down to 150 F. No more cranking to start a hot motor with hot fuel in the carb.
Get an electric pump, 4 core 1000 hp aluminum radiator, Twin Stall electric fans and you will have no problem with cooling.
The next contender is the gilmore belt electric motor driven mech pump.
Anything else is for wimps and wussies in the non-performance world.
I listed the upside to greater cooling at low speed. I did not get into the nitpicking of hp gains or losses. Even though my previous Stewart racing pump was rated at near 3.8 hp max @4500 - 9000 rpm
Some Meziere electric pumps cost more than $600, and that doesn't include adapters, fittings and wiring harness :
http://www.summitracing.com/parts/MEZ-WP319S/
i would run my mechanical setup for decades. At worst my fan belt will last 6-8 years.
its the fear of that little electric motor fizzeling out that would keep me running a mechanical setup.
There is no set power loss for all clutch fans and they never completely disengage.
Depending on the application, the fan pitch and the specific clutch used, they are all different. The same clutch was not used in all C3's.
Not engaged can mean anywhere from 20 to 30% pump rpm and engaged anywhere from 70 to 90% pump rpm and anywhere in between.
But to repeat, they're not for everyone. The significant benefits don't outweight the cost for most.
http://www.meziere.com/ps-632-600-wp101bhd.aspx
Essentially, you do have a belt driven windshield wiper and heater fan- they get their power from a very inefficient alternator.
Both pumps have their place . One thing about a mechanical pump is that most times when one starts to go up on you ,its not immediate failure,lots a time the pump will start to leak coolant or make a noise,but on a electric pump,when it goes,it goes.
