Thrown Rod on 383 Stroker
Old May 9, 2010 | 09:45 PM
johndarrah24's Avatar
johndarrah24
Default Thrown Rod on 383 Stroker
I had a new 383 Stroker installed in Dec 08. She drove great for awhile then I discovered a transmission leak so I let her sit for a few months. About a month ago, I finally had the seal replaced. Last night I was coming home from a friends house. I stopped at a red light when all of a sudden she backfired, the engine died and started smoking. I heard a metal clanking sound underneath the car. Some people stopped and helped me push her into a parking lot. Then I went over to the street and found a single metal rod laying on the ground. I am not an engine guru but I know this isn't good. What is the best/ and or cheapest way to get it fixed? Do I need to buy a brand new short block? Any help or insight you can give would be greatly appreciated. I live in Cibolo Texas outside of San Antonio, so if anyone else lives around here and can recommend a good shop, I would appreciate it.
http://s769.photobucket.com/albums/x...t=DSCN0672.jpg
http://s769.photobucket.com/albums/x...t=DSCN0673.jpg
http://s769.photobucket.com/albums/x...t=DSCN0692.jpg
http://s769.photobucket.com/albums/x...t=DSCN0690.jpg
I also found an additional two holes in the oil pan. One on the drivers side and two on the passenger side.
Old May 9, 2010 | 10:14 PM
mr303's Avatar
mr303
Some photos may help on this one. I've never seen a rod (con rod) thrown out of a engine before, must have made an awful big hole somewhere!
Old May 9, 2010 | 10:15 PM
TimAT's Avatar
TimAT
Can you post a picture of the rod?? It's unusual for a rod to actually "leave the building" at low RPM, but anything is possible.
Old May 9, 2010 | 11:05 PM
johndarrah24
Default Pics of Rod
I will post some pics tomorrow. I just had her towed home to my garage this morning. After work tomorrow, I will jack her up and take some pics of both the rod and where the oil is leaking out of
Old May 10, 2010 | 03:13 PM
Belgian1979vette's Avatar
Belgian1979vette
A rod coming out of the engine ???
If it comes out at all , it has to comes out in pieces. If it is still in one piece, which i can hardly imagine it must have come loose from both piston and crank, which is hardly something I can imagine.
Are you sure it is a conrod ?
Old May 10, 2010 | 03:26 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It was a rod of some kind who knows until he posts a pic, I doubt it's a connecting rod but I've been wrong before
*Edit, just read about the oil leak so it could in fact be a section of the con rod
Old May 10, 2010 | 06:28 PM
johndarrah24
Default Some pics of the rod and oilpan
I went out and jacked her up. I found a dime size hole on the oil pan near the starter where the rod came out of. How do I post the pics on here so you guys can view them?
Old May 10, 2010 | 06:38 PM
Clams Canino's Avatar
Clams Canino
Go to the "help forum" and look for the sticky thread on posting pics. It's easy.
I think the "for sale" section has that info as well.
A connecting rod does not come out of a dime sized hole.
Perhaps it's a rod bolt?
-W
Old May 10, 2010 | 06:58 PM
Gordonm's Avatar
Gordonm
Your picture shows a pushrod. That actuates the valve. How the he$$ did that come through the oil pan. That is in the valve train in the upper part of the motor. Anything is possible but that is strange for a pushrod to come out the oil pan.
Old May 10, 2010 | 07:03 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
A push rod??? Sounds like it might be equivalent to the '63 "Magic" bullet in Dallas.
Old May 10, 2010 | 07:14 PM
johndarrah24
I have no idea how or why it came through my oil pan but unfortunately it did. So basically my engine is shot right? What type of work would be needed to be done to fix it?
Old May 10, 2010 | 07:23 PM
...Roger...'s Avatar
...Roger...
No that rod doesn't mean your engine is shot but this should be one for the record books.
Old May 10, 2010 | 07:24 PM
Gordonm's Avatar
Gordonm
It depends on what let go in the motor. If the pushrod came down through the motor yes there is something broken in the block and it would be trashed. You or have someone take the valve covers off at least to see what is happening. The best thing would be to take off the intake and see how the pushrod came down through the block.
This had peaked my interest on how this happened.
Old May 10, 2010 | 07:25 PM
L88Plus's Avatar
L88Plus
That's a pushrod, not the feared connecting rod. You probably have a blown up lifter and maybe a damaged valve, too. You may be lucky, though, but you'll for sure have to pull the engine to tell exactly what's damaged and what isn't. Once the pushrod made it to the pan, the spinning crank hammered it through.
Old May 10, 2010 | 07:29 PM
johndarrah24
Thanks to all for the help and guidance. I will call an engine shop tomorrow to see what they say. Thanks again
Old May 10, 2010 | 07:31 PM
'75's Avatar
'75
That pushrod looks surprisingly good after having suffered such abuse. I've never seen one come through the pan. I saw one come through the hood on my buddies 340 Duster back in the day. I had a connecting rod or what was left of it,come up and break the cam once too.
Old May 10, 2010 | 07:33 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Was just thinking that which prompted coming back into this thread.
To Thrown Rod on 383 Stroker
Old May 10, 2010 | 07:39 PM
Gordonm's Avatar
Gordonm
It does not even look scratched. You would think if the crank hit it that there would be signs of damage. To come down through the engine it has to get by the lifter the cam and the spinning crank and rods. Something would have dinged it up and then hitting going through the pan and hitting the ground should damage it.
Old May 10, 2010 | 07:41 PM
73jst4fun's Avatar
73jst4fun
I was thinking the same thing when I saw the pic of that rod, you would think it would show some kind of beating....
Old May 10, 2010 | 07:43 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This is where it looks like the push rod came through. Another pretty amazing feat.
