Which gauges do you have?
Old May 10, 2010 | 07:37 PM
1976stingrayNC's Avatar
1976stingrayNC
Cruising
Default Which gauges do you have?
Going to replace the worn out and mostly non-functional gauges in my '76. There are obviously 5 holes in the bezel. I need to figure out which 5 gauges to get. I'll definitely replace oil pressure, water temp, and fuel. I'll probably replace voltmeter, although I don't know why I need this info every time I drive. I don't think I need the clock. The question is, what do others think are the 5 best gauges to have.
Old May 10, 2010 | 11:48 PM
vette427-sbc's Avatar
vette427-sbc
Keep a volt meter or ammeter- they let you know if your charging system is working or not. I have fuel level, water temp, volts, oil pressure, and oil temp. Other gauges you might put in place of the clock could be wideband A/F ratio or vacuum (both good tuning devices).
Old May 11, 2010 | 12:15 AM
TimAT's Avatar
TimAT
Old May 11, 2010 | 12:31 PM
7T1vette's Avatar
7T1vette
Probably the most "necessary" gauges for a C3 are: fuel gauge, oil pressure, water temp, ammeter (it does tell you if the battery is charging or if a belt has been thrown), and a vacuum gauge. The vacuum gauge can tell you if there is a leak in the system, help you diagnose engine problems, and help you drive to best mileage (if you ever want to do that..). Another alternative gauge is a transmission oil temp gauge...if you have an auto tranny.
Chances are that the lack of function on your gauges is not the gauges themselves...more than likely electrical problems and/or sensor problems. Those same issues will have to be dealt with if you replace the gauging with new ones. Why not just fix what you have?? {Just a thought...}
Old May 11, 2010 | 09:01 PM
1976stingrayNC
Cruising
Default thanks for the replies
Yes, I am going to put the multimeter to work this weekend on the old gauges and wiring. The faces are a little worn, though, and ultimately I will want to upgrade. I appreciate the input.
Old May 12, 2010 | 10:02 AM
73StreetRace's Avatar
73StreetRace
Center Console :
Water Temp, Fuel level, Voltmeter, Oil Press, Ammeter ( stock ),
Passenger Side :
Oil Temperature, Fuel Press, AFR Monitor, Intake Manifold Vacuum...
Driver Side :
Speedometer, Tachometer + Shift Light
On the windshield : G-Tech SS computer
All gauges are full sweep, mechanical or electrical, AutoMeter Sport-Comp.
Don't forget to use a co-pilot too, he's or she's very useful to check the gauges of your Boeing from time to time
Old May 12, 2010 | 11:13 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
AutoMeter SportComps fit nicely ..
Old May 12, 2010 | 11:39 AM
73StreetRace
They almost have the same look as the stock instruments.
To Which gauges do you have?
