Flex-A-Lite 210's
Old May 13, 2010 | 11:40 PM
ssenay72's Avatar
ssenay72
Default Flex-A-Lite 210's
Thinking of putting 210's in, does anyone have one and if so how easy was it to mount? Custom brackets or straight forward install?
I have a flexalite 180 in there now but the brackets are universal and it doesnt fit right.
Going to stick with fex a lite because i bought their relay system and it wasnt cheap.
Pictures would help. thanks.
Old May 13, 2010 | 11:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It's easy to mount because it comes with plastic thingys that you push through the rad fins and secure with push on plastic thingys.
I had them on my 406ci and they worked fine. It was a 550HP motor so I would get a slight temp creep if I got stuck in traffic on a hot day, otherwise it worked great
Here's a pic, hard to get a pic of electric fans because the rad is on an angle, oh wait that's a pic of me when I had hair
Here's the FlexoLite 210's
Old May 14, 2010 | 07:04 AM
ssenay72's Avatar
ssenay72
is there a way to mount it without going through the radiator? id rather use brackets. I had a bad experience running mounts through the rad on my camaro. (leaks!)
Old May 15, 2010 | 03:00 AM
MotorHead's Avatar
MotorHead
Comes with a primitive bracket setup too if I remember correctly, I never had any leaks, gotta crank then down so the fans don't move
To Flex-A-Lite 210's
