HELP!! Need angine build code detective...
Old 03-17-2002, 10:00 PM
WeasleVette454
WeasleVette454's Avatar
Default HELP!! Need angine build code detective...
Is there any way to find out the specs on this engine or confirm what it is? It is supposed to be a crate motor purchased within the last year or so. It's a 454 and the build numbers from the right front (passenger) bank are T8B515790. Any help in the right direction would be muchly appreciamicated!
Weasle :D
Old 03-17-2002, 10:29 PM
lbell101
lbell101's Avatar
Default Re: HELP!! Need angine build code detective... (WeasleVette454)
I think we will need more info on this one. I can't find anything about that number.
What is the block casting number?
What is the block casting date code?
Is that ALL the stampings on the pad?
Old 03-21-2002, 09:49 PM
WeasleVette454
Default Re: HELP!! Need angine build code detective... (lbell101)
Is your offer still open? I've been really busy the past few day. Tonight I even got the pleasure of doing my taxes! If you feel you can help me, I'll get the numbers that you requested and send 'em your way. Thanks!
Weasle :D
To HELP!! Need angine build code detective...
Quick Reply: HELP!! Need angine build code detective...
