If they won't shut off the white wire circuit is going to ground either through the body or one of the other wires. What do you mean right position on the switch ? As long as they are all on there and separated they are right.
The door plunger female switch and the electrical male have three wires in a moulded plug. It seems that you can rotate the male plug and put it in a different location on the door switch.
How do you know if it is right?
I am thinking of removing the door plunger and gounding the outside. Hold the plunger in for 60 seconds and see if I have the right location.
I really do not want to create a short by doing this method.
All those wires are seeking ground so grounding them won't hurt anything. The switch position won't matter but all 3 wire must be kept away from each other. When the switch comes out it merely grounds all 3 wires to the metal pillar post.
Remove the switch and pull all the wires outside and remove them from the switch,wait for the lights to go out,if the lights don't go out then its not that switch causing the problem.
For your info the white is for the courtesy lights the tan is for the key buzzer, the blue is for the alarm
