Help Finding Electrical Connectors
Old May 16, 2010 | 04:38 PM
mconwayjr's Avatar
mconwayjr
Default Help Finding Electrical Connectors
Does anyone know of a good source to find electrical connectors / harnesses for a 1980?
I am trying to locate the small cylindrical 3-pin connector that goes to the driver's side door jamb switch. I ordered the new door jamb switch but the old connector has one of the pins broken off. The existing pins do not fit the new door jamb switch either.
I am having a really tough time locating this part. I tried going to Radio Shack to see if I could just replace the pins, but they didn't have anything that size.
Thx,
Marshall
Old May 16, 2010 | 04:55 PM
ssenay72's Avatar
ssenay72
check napa online, i found some stuff through them, never would have thought they would have either.
Old May 16, 2010 | 05:47 PM
Duke94's Avatar
Duke94
You can buy the harness here.
http://www.lectriclimited.com/mainpage.htm
And connectors here.
http://www.wiringharnessparts.com/main_page.html
Gary
Old May 16, 2010 | 06:54 PM
mconwayjr's Avatar
mconwayjr
Thanks for the info guys!
Has anyone else had to replace these door jamb switches on a 80 vette? I tried installing the switches to perform some tests and the threads on both switches are not even long enough to pass through the steel and get a nut on the back side.
I'm assuming that is how they are supposed to be installed. I don't see any threads on the inside of the hole suggesting they were stripped, etc.
Marshall
Old May 16, 2010 | 07:12 PM
Duke94's Avatar
Duke94
On my 71' and 78', there is a threaded plate riveted to the door jam and the switch screws into it. Sounds like yours may be striped, but 80' could be different.
Old May 16, 2010 | 07:26 PM
mconwayjr's Avatar
mconwayjr
yeah, I was afraid that might be the situation. I have the same metal plate riveted to the door jamb on both sides. Unfortunately, no sign of threads in either hole.
Old May 16, 2010 | 07:44 PM
mconwayjr's Avatar
mconwayjr
Ok. it seems that just re-tapping is out of the question. The threaded switch passes through the hole without interference. Does anyone have a suggestion how to properly insert these switches?
I don't know if I can drill a larger hole and insert some sort of sleeve that would have the proper threaded hole diameter in the center. I wouldn't even know where to find something like that.
The only other option I can think of which I'd rather not do because it seems to be very "bubba-ish" would be to silicone the switches into the holes; hopefully securing them into place yet not making them permanent incase they need to be replaced again.
I know there are a lot of people with more garage time in here than me, so any suggestions are welcomed.
Thx,
Marshall
Old May 16, 2010 | 07:50 PM
70Donnybrooke's Avatar
70Donnybrooke
Is this the switch at the front or the one in the back?
Old May 16, 2010 | 07:52 PM
mconwayjr's Avatar
mconwayjr
Both door jamb switches at the front of the door on the driver's and passenger side. The switches that operate the courtesy lamps.
Marshall
To Help Finding Electrical Connectors
