How long can a mech pump be run empty?
Old May 18, 2010 | 12:23 PM
007husky's Avatar
007husky
Default How long can a mech pump be run empty?
How long can a mechanical pump survive if the car is run with an electric pump and the mechanical pump with the hoses disconnected ?
My pump was all over the place, pushing way too much pressure into the carb. it would have peaks of 15 or more psi and valleys of what looked to be 0.
Switched temporarily to a Mr gasket electric pump and i have 5 psi steady into the carb...
what are the ill effects i ll get from running the mechanical pump without gas in it ? will it cease?
Also seems that the gas gets heated pretty good with the electric and mechanical pump and can see air pockets in the glass filter.
My headers are close enough to the metal fuel lines that radiant heat is considerable and heats the gas. Should I worry about this ?
I don`t think this has caused any problems on fuel delivery.
Thanks !
Old May 18, 2010 | 12:58 PM
929nitro's Avatar
929nitro
Don't know how long it would last. Any time I switched to electric I pulled the manual off and the pushrod out and put a cover plate on with gasket. Looks better IMO.
Old May 19, 2010 | 01:42 AM
73StreetRace's Avatar
73StreetRace
That's what I would do, too.
About your problem of radiant heat, you can use ThemoTec products to insulate your fuel pipes :
http://www.summitracing.com/search/Brand/Thermo-Tec/
It's not very expensive but it is very efficient. Here is what I did with my braided hose and fuel lines :
Old May 19, 2010 | 08:38 AM
...Roger...'s Avatar
...Roger...
If the pump fluctuated from 15-0 its toast ,trash it.
Get rid of the glass filter.
Old May 19, 2010 | 10:17 AM
1ARACE's Avatar
1ARACE
Thanks !
If it's not vapor locking it should be fine as is, but you could also attach a wooden clothespin(s) to the fuel line for a little more peace of mind...just remember to take it off at car shows...I forget quite a bit to do that, but makes for conversation though.
Get rid of the glass filter also.
Old May 19, 2010 | 10:47 AM
jordan89's Avatar
jordan89
Get rid of that glass filter!
Old May 19, 2010 | 10:51 AM
007husky's Avatar
007husky
Thanks for all the answers !
my car is.. far from show quality, so i don`t have to worry
just out of curiosity why get rid of the glass filter ?
007husky's Avatar
007husky
Your engine bay looks awesome !
Old May 19, 2010 | 10:53 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by 1ARACE
If it's not vapor locking it should be fine as is, but you could also attach a wooden clothespin(s) to the fuel line for a little more peace of mind....
Wood is actually a pretty good insulating material and if anything is trapping the heat in the fuel line, not helping get rid of it.
GM came up with an excellent solution for vapour lock and incorporated it on all later C3s. It amazes me to see how many people defeat this system.
Three ports pumps/bypass lines are your friend.
Old May 19, 2010 | 11:24 AM
zwede's Avatar
zwede
Glass has a bad habit of cracking/shattering at which point you're pumping gas all over your engine and exhaust. Many a cars have been turned into cinders that way.
Old May 19, 2010 | 11:42 AM
007husky's Avatar
007husky
Got it, thanks !
To How long can a mech pump be run empty?
