'81 choke question
Old May 19, 2010 | 12:56 AM
sabre1981's Avatar
sabre1981
Default '81 choke question
Working on rebuilding a carb and today I picked up a new choke, but now I am at a lost as to how it stays on. I am guessing there is a cap of sorts that gets attached to the three rivet areas. None of this was present when the carb was built.
Old May 19, 2010 | 01:30 PM
zekie's Avatar
zekie
you could drill and tap the holes and use screws to hold your choke in place.good luck
Old May 19, 2010 | 01:40 PM
lars's Avatar
lars
There are 3 sheet metal clips that secure the choke cover to the housing using rivets. You can also tap the holes and install screws. The clips come in all carb rebuild kits.
Lars
Old May 19, 2010 | 09:13 PM
sabre1981's Avatar
sabre1981
The choke came with three rivets, the little lip on them will hole the choke in place? There isn't supposed to be any cap that goes over the choke?
Old May 20, 2010 | 09:17 AM
lars's Avatar
lars
As stated earlier, there are 3 sheet metal clips that secure the cover, and these clips are riveted to the housing. The clips come in all carb rebuild kits. Install the clips.
Old May 20, 2010 | 12:20 PM
BKarol's Avatar
BKarol
Does yours look like this?
Old May 20, 2010 | 12:48 PM
lars's Avatar
lars
karol posted a correct photo of a pre-79 choke converted to electric. 79 and later used rivets from the factory, but the holes can be tapped for the screws as shown in the photo. The clips under the screws are the retainer clips that are provided new in every carb rebuild kit - they must be installed to retain the choke.
Lars
Old May 21, 2010 | 11:55 AM
sabre1981's Avatar
sabre1981
OK, got it. Thanks Lars and Karol.
To '81 choke question
