driver door will not open
Old May 19, 2010 | 01:57 PM
cab's Avatar
cab
Default driver door will not open
my door will not open from the outside. i have taken the door panel off and see a spring under the handle loose and a linkage that may need to be adjusted. problem is i cant figure out how to get to it. any suggestions or a link? thanks.
Old May 19, 2010 | 02:49 PM
Cmflorida's Avatar
Cmflorida
Cruising
Hey hope this helps. there is a little tool you need. It looks like and (basically is) a bent flat head screwdriver. It makes the job MUCH easier. Here's a pretty good work up on how to use it, and repair your door. Good luck.
http://www.corvettemagazine.com/tech...le-repair.html
Old May 19, 2010 | 03:41 PM
BritewhiteC3's Avatar
BritewhiteC3
cab, this problem has occur a bazillion times. . . . search is your friend. . .
heres an old post with a great pix on post 2 http://forums.corvetteforum.com/c3-g...uck-latch.html
hope it helps
To driver door will not open
