Pass. Door Latch Sticks Open!
Old May 19, 2010 | 03:02 PM
hugie82's Avatar
hugie82
Default Pass. Door Latch Sticks Open!
After replacing the outer door handle I ran into this problem. When I open my pass door it won't latch closed again I have to work the door lock and the inner door handle until the latch snaps back. Then the door will close.
Should I just replace the whole locking mech.(I see the latch is pretty expensive) or is there a fix? I tried cleaning it, oiling it and adjusting the rods.
Old May 20, 2010 | 04:01 PM
hugie82's Avatar
hugie82
Nobody has had a problem with the door latch here???
BUMP
Old May 21, 2010 | 08:24 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
the only thing I can say is make sure all the linkages are moving freely inside the door, the one near the top is hard to get to, so is the locking one , Ron
Old May 21, 2010 | 10:27 AM
7T1vette's Avatar
7T1vette
The latch mechanism and linkages need a really good cleaning and need to be re-lubricated with white lithium grease (tube-type goo...not spray stuff, if you can help it).
Old May 21, 2010 | 08:56 PM
hugie82's Avatar
hugie82
OK, so there is no parts that wear out in the latch mech. I cleaned it in the door but do you guys think I should remove it, clean and grease ???
Thanks for the advise
To Pass. Door Latch Sticks Open!
