1974 Side Pipe installation
Old May 20, 2010 | 08:34 PM
toolman0114's Avatar
toolman0114
Default 1974 Side Pipe installation
I just put a set of side pipes, with fiberglass covers, on my 74 vette. Just wondering if anyone else has done this and what it looks like, they look good, but I can see the pipe below the bottom of the cover, is this normal? or should threy tuck completely into the fiberglass cover?
thanx...
Old May 24, 2010 | 06:10 PM
toolman0114
I would like to post pics but under the posting rules it say "you may NOT post attachments" why not?????
Old May 24, 2010 | 06:19 PM
Alan 71's Avatar
Alan 71
Hi T,
You can post pictures!
Upload them to a site like PhotoBucket, then copy the picture's IMG CODE into the body or under the message of your post. You'll see the picture when your post appears.
It's easy!!!
Regards,
Alan
Old May 24, 2010 | 06:37 PM
jordan89's Avatar
jordan89
Originally Posted by Alan 71
Hi T,
It's easy!!!
Regards,
Alan
Old May 24, 2010 | 11:22 PM
toolman0114
Old May 25, 2010 | 11:31 AM
jimvette999's Avatar
jimvette999
thanx...
it's normal for half the muffler to be exposed
Old May 25, 2010 | 12:32 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I have a 74 with the same setup, my pipes hang lower than that (although I'm trying to figure out how to tuck them up higher).
Old May 25, 2010 | 12:39 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
http://forums.corvetteforum.com/c3-t...nging-low.html
Old May 25, 2010 | 03:43 PM
Alan 71's Avatar
Alan 71
Hi T,
With my 'over the counter' pipes and covers there is about 1 5/8" clearance between the bottom of the frame rail and the top of head pipe headed to the muffler. Is yours more than that?
If I lay with my head on the ground I can see about 3/8" to 1/2" of the muffler below the cover.
Remember, originally, the bottom lip of the fender behind the front wheel was cut to allow the pipe to clear the fender. Was that done for your installation?
Regards,
Alan
Old May 25, 2010 | 11:36 PM
toolman0114
I guess these are installed correctly, thanx for all the help...
To 1974 Side Pipe installation
