help no power stiring
Old May 26, 2010 | 08:37 PM
johnrodz's Avatar
johnrodz
Default help no power stiring
I just replaced my power stiring valve and cylender assy on my 81 c3. Now i have no power asist at all unless i jerk on the stiring wheel quickly . I am shure it is installed properly. It just dosent work right .Any help would be great. Johnrodz
Old May 26, 2010 | 10:14 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
.....double check how you have the hoses going into the steering valve on the left side-they can be accidentally switched and when that's done it will not work right. The lines cross over each other forming what looks like to be an "X" when they're installed correctly. The lines going into the top can't be interchanged as they are two different sizes.
...did you bleed the air out of the system by disconnecting the ram to frame connection and operating the steering wheel lock to lock several cycles??? There is a distinct procedure that should be followed once these parts are re-installed and fluid put in them for the first time for them to operate correctly.
Old May 26, 2010 | 11:09 PM
johnrodz's Avatar
johnrodz
No but I will do so am tomoro and see what happens .Thanks Paul
To help no power stiring
