r12 needed this weekend
Old May 28, 2010 | 12:54 AM
LT1driver's Avatar
LT1driver
Default r12 needed this weekend
leaving abilene, tx tomorrow (fri) or sat going to lubbock, amarillo and then to albuquerque, new mexico....anybody have couple cans I can get on way thru, system still uses and has r-12 in it but needs charge, 1-2 cans will do I am sure. thanks. pm me a phone number and I will call and set up a meeting..thanks again.
mike
Old May 28, 2010 | 01:15 AM
striper's Avatar
striper
Call this company, they are in Nashville, TN (I believe). They have an R-12 compatible product. 866-865-6233.
Old May 28, 2010 | 07:27 AM
...Roger...'s Avatar
...Roger...
R12 is expensive,suck that stuff into a can and drop off at an AC shop and fill your system with 134. Walmart has a kit and the 134 , cost you around $50.
Old May 28, 2010 | 10:52 AM
7T1vette's Avatar
7T1vette
Changing your system over to use R134a is not as simple as replacing the refrigerant. And you can't get all that stuff done by 'this weekend'.
Start calling around to Auto A/C repair shops in your area and ask them if they have any R12 they can add to your system. Some of the shops still have a supply of R12 that they can ADD to auto systems. It won't be cheap...but it will be less expensive than changing over your system. {And it will be a lot quicker to get done.}
Old May 28, 2010 | 11:13 AM
...Roger...
Actually it is. It is not actually the correct way to do it but what do you have to lose if it works ? Changing it over by the rules means the entire system has to be taken apart , all the rubber o-rings and lines have to be replaced along with many other things.
I've done many with the Walmart style kit and they all still work,so to each his own.
Old May 28, 2010 | 11:21 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Drive a few more hours to Phoenix and I'll do it for you.(R12)
Old May 28, 2010 | 01:39 PM
LT1driver's Avatar
LT1driver
thanks AZ but little far from where I am...lol.
Old May 28, 2010 | 01:48 PM
Rmorgan&11's Avatar
Rmorgan&11
Call NAPA and ask for FREEZE-12 they usually stock it ..at least around here...
it is a direct subsitute for R12 and is compatable with your system & ozone friendly. just a little higher than 134 but way cheaper than R12....but you got to know someone with the R12 charging hoses ....or have your own
Googled and shows Auto Zone may have also
here it is >
http://www.amazon.com/Freeze-12-Refr.../dp/B002GQ0QQO
Old May 28, 2010 | 06:15 PM
71coupe454's Avatar
71coupe454
I do this all the time in my shops for customers who can not afford or the car is not realy worth a correct retro-fit service. Works fine most of the time.
Old May 28, 2010 | 06:27 PM
Ironcross's Avatar
Ironcross
any home AC service has R12.....probably the same service that services your home could recharge your car. But its not going to last if the cars unit it not correctly repaired.....The alternative is 134 with the correct fittings to change it over...we have found its not quite as cool by a few degrees as R12 though....but it does work
Old May 28, 2010 | 08:00 PM
noonie's Avatar
noonie
Most of the home service a/c guys around here don't have r12 since most residentioal uses r22 and the newer 410a. But then there are a gazillion a/c companies around here too.
Refrigeration service, as in grocery store and restaurant coolers, still largely use r12 and perhaps one of those places can give you a name of a local service guy with r12.
Probably up north with less service outfits, the a/c guys tend to spread themselves a little wider.
To r12 needed this weekend
