Changing marker bulbs
May 28, 2010 | 12:16 PM
Sorry if this is a really simple question, but how do you change the corner marker lights on C3's? You have to go behind them?
May 28, 2010 | 12:33 PM
Just twist and turn the socket, then pull out of the housing, then just pull out the bulb and then just replace the bulb and twist the socket back in the housing.
May 28, 2010 | 12:36 PM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Reach up behind the quarter panel/fender, grab the bulb socket and turn 1/4 turn counter clockwise and pull the socket from the marker housing. The bulb is a flat blade type bulb that simply pulls straight out.
May 28, 2010 | 12:42 PM
Quote:
Originally Posted by
HOOAH
May 28, 2010 | 12:59 PM
Bulb is a 194.
Rear markers are easy to access.
Front fender markers are a biatch to get to unless you have 3 elbows and arms like Stretch Armstrong.
May 28, 2010 | 01:52 PM
blckslvr79
Bulb is a 194.
Yep, be careful. Something like this normally results in a "frame off" restoration! That's what drove me there.
May 28, 2010 | 02:23 PM
HOOAH
A frame off might be easier!
May 28, 2010 | 03:54 PM
Hi K,
Just follow everyone's direction; here's a picture of the rear driver's side light. Twist the white plug a quarter turn.
Regards,
Alan
May 28, 2010 | 06:17 PM
thanks for the help guys, i'll give it a try this weekend.
1982 ,
bulb ,
c3 ,
c6 ,
changing ,
corner ,
corvette ,
marker ,
rear ,
replace ,
side
