1968 Automatic Accelerator pedal lever and bracket
Old May 28, 2010 | 02:58 PM
blhar15's Avatar
blhar15
Default 1968 Automatic Accelerator pedal lever and bracket
I have a 1968 with TH400 auto transmission, 427 390HP. I do not think the accelerator pedal assembly is the correct one for the car. It is also missing the transmission kickdown switch. Does anyone have pictures under the dash of what the correct accelerator pedal bracket should look like with the kickdown switch?
Old May 29, 2010 | 07:49 AM
blhar15's Avatar
blhar15
Could anyone with a 1968 or 1969 with a THM400 automatic take a picture for me under the dash of their accelerator pedal assembly?
Old May 29, 2010 | 07:43 PM
onearmblack's Avatar
onearmblack
6th Gear
Not sure if this helps, but here ya go. Bubba has certainly been under this late 68 dash, but the hardware is still stock. Let me know if you need a different angle or something.
http://i877.photobucket.com/albums/a...s/DSC06690.jpg
Old Jun 13, 2010 | 05:30 PM
blhar15's Avatar
blhar15
Does anyone know where I can find a 1968 kickdown switch and bracket assembly?
Old Jun 17, 2010 | 09:27 AM
onearmblack
6th Gear
I put a few more pics/angles up...Maybe they'll help you better identify your donor. Good luck!
http://s877.photobucket.com/albums/a.../vette%20pics/
To 1968 Automatic Accelerator pedal lever and bracket
