Spreader Bar Question
Old May 29, 2010 | 08:25 PM
spedaleden's Avatar
spedaleden
Default Spreader Bar Question
I am thinknig of adding a spreader bar for better support on the front end. I have a fan not electric fans and was wondering what you all think of it since you have one.
I am thinking of VBP
Is the front end more stable, like when driving over railroad tracks or large bumps in the road, and on a scale of 1 to 10. 10 being highest please rate.
Dennis
Old May 29, 2010 | 09:10 PM
Gordonm's Avatar
Gordonm
I would give it a 9. It definitly stabalized the front end a lot more after it was installed. No doubt a benefit.
Old May 29, 2010 | 09:31 PM
spedaleden's Avatar
spedaleden
You the man Gordonm
Old May 29, 2010 | 10:10 PM
78IndyPace's Avatar
78IndyPace
At least 2 of us on the forum had to fab end plates from 2" wide bar stock in order to have sufficient material for welding the tabs and still have the bar clear about 1/4" below the fan pulley. The plates you'll get are only 1". Not a big deal, but for VBP's price they should provide parts that work.
While I can feel a bit more stiffness with the bar on my 78, it's not a huge difference. But it's also a very low mileage car with no rust and a solid stock suspension with Bilstein sport shocks on all corners. I would not do it again on my particular car.
Old May 30, 2010 | 12:09 AM
Ray Y's Avatar
Ray Y
I'm running twin Spal electric fans with a DeWitts radiator so the VBP bracket works fine. It is a very worthwhile suspension upgrade and I know you will see a positive difference if you decide to use one.
Old May 30, 2010 | 01:23 AM
682XLR8's Avatar
682XLR8
I had to use 2" bar stock as well to get mine to fit....
Old May 30, 2010 | 08:36 AM
Paul L's Avatar
Paul L
I have not had experience with the VBP unit. This one came from another Forum sponsor (Speed Direct).
There seems to be a modest increase in front end stability but 1) I do not drive aggressively and 2) my front end was pretty solid to begin with. My car is a hobby and sometimes I just like to fool about.
http://speeddirect.com/index.aspx?nodeID=183
Old May 30, 2010 | 01:24 PM
MN-Brent's Avatar
MN-Brent
Made a difference in mine. I cant say a 9, as I think my frame was still very strong. I would say 6-7 due to that fact.
But, Spreader bar, in combination with Rack and Pinion really makes the front end feel SOLID and I would give this combo a 9.
I have a third party comparison also. While I was trying to sell my car last fall, a fellow that had been test driving several other C3s came and test drove mine. He said "Hands down, this car handles and steers the best of all the Vettes he has driven".
Old May 30, 2010 | 09:44 PM
MN80Vette's Avatar
MN80Vette
I don't have a mechanical fan, so I didn't have any of the complications of a spreader bar fitting around a mechanical fan. The VBP spreader bar I installed DEFINITELY made an improvement!
To Spreader Bar Question
