Temp guage
Old May 30, 2010 | 11:52 AM
3vetts's Avatar
3vetts
Default Temp guage
Hey all. Need a little help with my temp guage, on 76 Stingray. Put new temp sensor, but guage still is not reading. How do I check the guage to make sure it is working?
Also just a quick note, the Stingray was being worked on for awhile and is back running again after the new engine and many other parts were put in.
Pete
Update. I did ground and the guage seems to be working but it still is not reading. I did replace the sensor and still nothing. Any more ideas out there?
Thanks again
Pete
Old May 30, 2010 | 12:53 PM
Chef-Greg's Avatar
Chef-Greg
Cruising
Use an ohm meter to see if you have a open or closed circuit
Old May 30, 2010 | 05:09 PM
Letournour 1850's Avatar
Letournour 1850
groud out the lead on the sencor your guage sould max out, I messed with mine a lot do not expect it to be totally accuate I swichted to a aftermarket mech in the end
Old May 30, 2010 | 05:28 PM
...Roger...'s Avatar
...Roger...
Key to ON , ground the sensor wire and gauge should go max hot, sender wire ungrounded (pulled off sender) gauge should go to cold.
Old May 31, 2010 | 01:19 PM
3vetts's Avatar
3vetts
Thanks for the replys. I will check it and let everyone know what I find.
To Temp guage
