Too much voltage
Old May 30, 2010 | 04:33 PM
Letournour 1850's Avatar
Letournour 1850
Default Too much voltage
Just put a new Batt in my vette and took it for a spin, I checked the voltage with a meter at idel was OK, but when I go up to Highway speed the volt meter reads 14.5- 16 Is this my regulator or just using more power at higher rpm
Old May 30, 2010 | 04:40 PM
...Roger...'s Avatar
...Roger...
What year ?
Old May 30, 2010 | 04:52 PM
Letournour 1850
1973 but have a volt meter
Old May 30, 2010 | 04:58 PM
...Roger...
OK , not sure of the gauge but the later model gauges from 78-82 read high ,actually in the red quite often. You might want to use your meter to be sure you are overcharging.
Old May 30, 2010 | 05:04 PM
Letournour 1850
OK checked it at idel with a hand volt meter was good just when I run it up the voltage incresses, at idel everything is OK at the alt and the batt
Old May 30, 2010 | 05:05 PM
Letournour 1850
Have a after market guage brand new
Old May 30, 2010 | 05:17 PM
...Roger...
If your gauge is accurate 16 is too high. Sounds like the voltage regulator. Is your alt a 3 wire ?
Old May 30, 2010 | 05:25 PM
Letournour 1850
? Have a pluggin with two and one bolted with boot ? POS and one bolted ? Neg guess 4 wire
Old May 30, 2010 | 05:32 PM
...Roger...
Thats a normal 3 wire. I 've seen the 1 wire aftermarket alternators read on the high side.
Take it off and have A.Z. or Advanced check it for you. Replacing the regulator is fairly easy.
Old May 30, 2010 | 05:35 PM
Letournour 1850
OK was thinking it was the reg but needed some expert advice like your self Roger
Old May 30, 2010 | 06:37 PM
Letournour 1850
Thanks Roger when down to O"Reilly had the alt test, failed everything so got a new one
To Too much voltage
