Starter bolt pattern
Old May 30, 2010 | 06:20 PM
rick1025's Avatar
rick1025
Default Starter bolt pattern
Can someone explain to me what BB applications used 2 bolt nose bolt patterns and which used 3 bolt patterns on the starters?Thanks
Old May 30, 2010 | 07:50 PM
Grumpy 427's Avatar
Grumpy 427
Any Chevy starter i have ever seen or used on BBC or SBC have been 2 bolt only with a brace on the front to the block. Some were staggered and some were inline.
Old May 30, 2010 | 08:09 PM
Gordonm's Avatar
Gordonm
They never used a 3 bolt starter. The small flywheel 153 tooth used the straight across starter. The big flywheel 168 tooth used the staggard starter. Pretty sure all BB used the turbo 400 which had the big 168 tooth flywheel so it would be the staggard starter.
Old May 30, 2010 | 08:30 PM
Ironcross's Avatar
Ironcross
Depends on the size of the BB, 454`S actually use the same starter as a 350. 396 and 427 use a cast iron staggered nose starter
To Starter bolt pattern
