rear suspension problem
Old Jun 1, 2010 | 11:18 PM
Dave True's Avatar
Dave True
2nd Gear
Default rear suspension problem
Hey new to the forum i have been reading for a while i have a problem with the rear suspension when i drive the car it sways back and forth today i had it on the lift looking at it and right rear tire was hanging lower than the left there is a little play in the bearings but not alot. any suggestions wuold be greatly appreciated thanks alot Dave.
Old Jun 2, 2010 | 12:32 AM
True Blue Vette's Avatar
True Blue Vette
In my experiance, that feeling usually comes from a loose strut-rod mounting plate, the differential crossmember bushings, or loose trailing arms (the shims fell out). The play you are saying is in the bearings is most likely play in the differential's stub axles. If you are moving the top of the tire/wheel in and out, have someone watch the axle shaft to see if it's moving in and out. If so, it's the stub axles, assuming your u-joints are ok. The tires can tend to droop at different heights depending on the angle the u-joints in the axle shafts were at when you put the car on the lift, but I would still check all nuts and bolts just to make sure something isn't falling off. Hope this helps. - Jeff
Old Jun 2, 2010 | 09:18 AM
w1ctc's Avatar
w1ctc
The shocks limit how far the suspension travels. You may have a bad shock allowing the wheels to hang differently.
Old Jun 2, 2010 | 09:35 AM
thegazman's Avatar
thegazman
Default thegazman
I had a similar problem and it turned out to be a missing c-clip that holds the stub axle in the differential.
To rear suspension problem
