Hi,
I made a tool from the drawing Roger posted out of a white plastic paint scraper from my local home supply store. It worked well for someone who isn't too well equipped to work with metal.
Regards,
Alan
I was slamming my shifter and all of a sudden I could barely get the tranny into gears. Kinda like the clutch wouldnt disengage all the way. Pretty certain I slipped the linkage somewhere on the tranny.
Going to have to crawl back from work and hopefully make it home. Thanks.
If it all of a sudden stopped working, it sounds like the mounting bolts came loose. The linkage can't just slip.
Yeah, it wasnt the linkage after all. Like Duke says, there is no way for it to slip. Not sure what's going on. Pivot ball check sounds like good idea.
