Upper Conrol Arm Pictures
Old Jun 4, 2010 | 01:30 PM
wheatpj's Avatar
wheatpj
Default Upper Conrol Arm Pictures
Can someone provide a few good pictures of (OE) right and left upper control arms? It's time to reassemble and I'm a little fuzzy about which is which.
thanks
Pat
Old Jun 4, 2010 | 03:11 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Old Jun 4, 2010 | 07:49 PM
Alan 71's Avatar
Alan 71
Hi Pat,
If you look at the arms from above you'll see that each arm has a more curved side and a straighter side from the shaft to the ball joint. The more curved side faces towards the front of the car.
Hope this helps!
Regards,
Alan
Old Jun 4, 2010 | 08:11 PM
Clams Canino's Avatar
Clams Canino
Here's a view looking down at my left upper.
Now, if you really need to see a right upper, put this image into PAINT and flip it 180.
Old Jun 4, 2010 | 08:21 PM
c3corvetteman's Avatar
c3corvetteman
Originally Posted by moonsteel
What he said.
Old Jun 4, 2010 | 08:34 PM
Clams Canino
Originally Posted by c3corvetteman
What he said.
How the hell can someone agree (or dissagre) with a stock diagram?
-W
Old Jun 4, 2010 | 09:52 PM
Rockn-Roll's Avatar
Rockn-Roll
-W
Cause it's not stock? They didn't use color for diagrams in the 70's...waaayyy too expensive because each page that had color would have needed to be silk screened or hand-painted or use one printer for each color...no multi-pass or multi-color printers back then.
Old Jun 4, 2010 | 10:11 PM
wheatpj's Avatar
wheatpj
Thanks guys for the great information; now I can start putting the front suspension back together without worrying whether I messed it up from the get-go.
Thanks again
Pat
Old Jun 4, 2010 | 10:49 PM
Clams Canino
OK OK.. I agree with the colors too.
Now... do I have to go to faceBook and "like" them as well?
-W
Old Jun 8, 2010 | 10:15 PM
whitehause's Avatar
whitehause
I had this same issue when I rebuilt my suspension about 2 weeks ago, and I also couldn't find a good picture that really showed which side went to the front.
Like Allan said(he's always right!) the more curved side goes toward the front. I'm not sure you could reverse the left and right without the ball joint end of the arm ending up at a really goofy angle anyway, but it's good piece of mind to know for sure.
Old Jun 9, 2010 | 04:52 PM
Alan 71's Avatar
Alan 71
Hi,
Well THAT certainly makes me nervous!
Regards,
Alan
Old Jun 9, 2010 | 05:36 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Passenger side:
Old Jun 9, 2010 | 07:01 PM
wheatpj's Avatar
wheatpj
Thanks guys for the great post...the information brings peace of mind to my rebuild process. That is the way I have them attached...curved side forward. I have the upper and lower control arms on and the bearing assemblies connected to the lower balljoints. Just need to compress the springs and connect the assemblies to the upper balljoints and the hard part should over.
Thanks All
Old Jun 10, 2010 | 10:03 PM
whitehause's Avatar
whitehause
Originally Posted by Alan 71
Hi,
Regards,
Alan
LOL....Ok....how about Alan's almost always right.
To Upper Conrol Arm Pictures
