Larger rotors for a C3?
Old Mar 19, 2002 | 11:46 PM
flynhi's Avatar
flynhi
Default Larger brake rotors for a C3?
Anyone runnin larger rotors on a C3 with, say, 17" wheels?
If so, what are you using for calipers?
[Modified by flynhi, 9:46 PM 3/19/2002]
Old Mar 20, 2002 | 09:07 AM
mrvette's Avatar
mrvette
Default Re: Larger brake rotors for a C3? (flynhi)
unless you are seriously into racing roll cage and all, forgetaboutit....
not worth the money, and most rotor packages are still thin rotors which will encourage warping....
I have done a bunch of hi speed stops, and you can't really kill a C3 rotor, and the brakes last just fine...
ME, I"d put the money somewhere else...
GENE
Old Mar 20, 2002 | 10:12 AM
redvetracr's Avatar
redvetracr
flynhi,
You are looking at 15"X9.5" wheels, 12.180 rotors and Corvette calipers. And YES it is very easy to "kill" a stock rotor. ...redvetracr
Old Mar 20, 2002 | 01:01 PM
ZD75blue's Avatar
ZD75blue
Default Re: Larger brake rotors for a C3? (redvetracr)
redvetracer... what kind of temperature do they warp at? and what kind of speed panic stops does it take to get the rotors that hot?
Would vented rotors not keep the heat down?
To Larger rotors for a C3?
