Charcoal canister question
Old Jun 6, 2010 | 03:58 PM
z10kl's Avatar
z10kl
Default Charcoal canister question
I know what it does, but why two hoses to the carb? One to the pcv valve to carb and another to the carb. Aren't both pulling vacume?
Old Jun 6, 2010 | 04:25 PM
budavid's Avatar
budavid
see the picture below, it will be clear when you see how it works
as far as I think you don't have the line on the left on the canister.
the purge signal will allow the canister to start "sucking" fuel vapor through the other vacuum line as you don't want it to escape when the engine is off.
I'm not a pro, but this is what I understand..
P.S you don't have the bowl vapor line I guess.
and the one Tee'd to the PCV is the one which sucks the fuel vapor, the smaller one should be the purge signal, without it the vapor should remain in the canister.
cheers.
Last edited by budavid; Jun 6, 2010 at 04:29 PM. Reason: to clarify the carburetor routing
Old Jun 6, 2010 | 04:29 PM
Alan 71's Avatar
Alan 71
Hi B,
Very nice schematic!
I don't think I've ever seen it.... where's it from?
On my 71 there are 3 lines.... 1 entering from the gas tank, 1 entering from the carburetor, and 1 leaving the canister headed toward the pcv and the carburetor.
Regards,
Alan
Old Jun 6, 2010 | 04:34 PM
budavid's Avatar
budavid
Originally Posted by Alan 71
Hi B,
Regards,
Alan
hello Alan,
easy, you can either right click on the image you see in the thread and go properties
or simply google images with keywords "charcoar canister" and it will come as the first image on resutls
the site is tpub.com, interesting technical stuff in it
Old Jun 6, 2010 | 04:40 PM
Alan 71's Avatar
Alan 71
Hi b,
ALLRIGHT!!!!
Thanks very much.
Regards,
Alan
Old Jun 6, 2010 | 04:44 PM
z10kl's Avatar
z10kl
Alan, you say one is entering from carb. What is it connected to? Is it not pulling vacume also?
Old Jun 6, 2010 | 05:34 PM
budavid's Avatar
budavid
I think it should "pull" and hold hte purge valve I guess, not pull with flow since it is used a signal..
maybe I'm wrong..
To Charcoal canister question
