Thread Size - Front Spindle 1968
Old Jun 7, 2010 | 02:37 PM
Clams Canino's Avatar
Clams Canino
Default Thread Size - Front Spindle 1968
Hi!
Two questions please?
1) What is the thread size of the front spindle nut on a 63-68?
Secondly... what is the thread size of the Spindle Dust Sheild Upper Mount Bolts? I ordered 2 new bolts.. but the threads in the blind hole are a little bungfe up and I want to chase them with a tap.
-W
Old Jun 7, 2010 | 05:24 PM
gbvette62's Avatar
gbvette62
1) My Corvette parts book tells me that the front spindle nut for 53-68 is a 3/4"-20.
2) I'm not sure what you mean by "Spindle dust shield upper mount bolts", but if your referring to the bolts that go through the brake backing plates, through the caliper support and into the steering knuckle, they are a 7/16"-20 x 2 1/4" grade 8.
Old Jun 7, 2010 | 06:31 PM
Alan 71's Avatar
Alan 71
Hi gb & W,
Isn't there also a single larger diameter bolt at the top that threads into a blind hole in the spindle casting? I know it's there but I can't find the size or thread.
Regards,
Alan
Old Jun 7, 2010 | 07:05 PM
73jst4fun's Avatar
73jst4fun
checked my book also, the bolts going through the brake backing plate to the knuckle are 7/16"-20 x 2 1/4" as mentioned by gbvette....
Old Jun 7, 2010 | 07:17 PM
Clams Canino
Originally Posted by Alan 71
Hi gb & W,
Yes Alan... that's the one I seek.
And I'm surprised it's 3/4 20 on the front spindle, that's the same as the rear spindle isn't it?
-W
Old Jun 7, 2010 | 09:15 PM
DZRick's Avatar
DZRick
Clams,
Is this the one your talking about?
I can take it to the hardware store tomorrow and find out exactly what size it is if you'd like?
Old Jun 7, 2010 | 09:29 PM
Clams Canino
Yes... that is the one!! Thanks!
-W
Old Jun 7, 2010 | 09:53 PM
DZRick's Avatar
DZRick
-W
Do you need me to take it to the hardware store to match it to a correct nut? I have to go into town anyways, so it's no problem.
Old Jun 7, 2010 | 09:59 PM
Clams Canino
If you could please. I won't get near a town for a few days.
-W
Old Jun 7, 2010 | 10:04 PM
DZRick's Avatar
DZRick
-W
You got it.
Old Jun 7, 2010 | 10:09 PM
gbvette62's Avatar
gbvette62
-W
Yep, the front spindle and the rear spindle use the same castle nut. They're found in the Corvette parts book in Group 6.022 and carried part number 378137 (now discontinued). The 69-82 front spindle uses a 27/32"-20 nut.
According to my Corvette parts book, the bolt in dzrick's picture looks to be an 11/16"-16 x 7/8". It's found in Group 5.002 and was part number 3864119. I don't know if it is still available from GM, but I doubt it.
Old Jun 7, 2010 | 10:40 PM
Kustom8's Avatar
Kustom8
Good men.
Old Jun 8, 2010 | 04:48 PM
DZRick's Avatar
DZRick
2 hardware store, NAPA, and then finally my local Chevy dealer no one could say for sure what size this thing is. I've got to believe gbvette62's is correct.
Not that I doubted gbvette62, just tried to follow through with my promise to check.
Old Jun 8, 2010 | 04:50 PM
DZRick's Avatar
DZRick
Originally Posted by Kustom8
Good men.
It's been awhile Kevin, good to see you back. Hows life treating you?
Old Jun 16, 2010 | 08:24 AM
Kustom8's Avatar
Kustom8
Not so well,Rick,but tomorrow is a new day.
Old Jun 16, 2010 | 08:30 AM
Clams Canino
Thanks again!!! I'm away from home a bit.. but will get back to work next week.
-W
Old Jul 10, 2010 | 05:25 PM
Clams Canino
Now that I'm home..
Does anyone know the torque value for that 11/16-16 bolt?
How about the other 2 bolt/nuts that hold that assembly together?
They are not in the AIM.
-W
Old Jul 11, 2010 | 03:44 PM
70BBvert's Avatar
70BBvert
My 70 service manual lists two specs which I believe are those bolts.
Caliper housing bolt @ 130 ft. lbs. (from brake section, may be referring to rear brakes)
Brake anchor bolt - disk brakes @ 120 ft. lbs. (from front suspension section - pretty sure this is the one you need)
The brake caliper is listed @ 70 ft.lbs.
I think the spindle, dust shield & rotor were supplied as an assembly.
Hope this helps.
Jim
To Thread Size - Front Spindle 1968
