ticking?
Old Jun 7, 2010 | 10:28 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default ticking?
I've got a ticking noise coming from both valve covers, any idea why both would start ticking at the same time?
Old Jun 7, 2010 | 10:45 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Do you have headers?(could be an exhaust leak)
Old Jun 8, 2010 | 12:13 AM
aussiejohn's Avatar
aussiejohn
Default Oil change???
Moon,
Have you changed your oil recently? I mean the brand and/or rating of your oil. If you are using an oil with an SG rating, it probably contains enough ZDDP to protect your cam/lifter interface from wear. If, however, you are using an SJ or SM oil, then they do not contain enough ZDDP to protect your cam and it has probably worn to the extent that the lifters have "dropped" and the tappet clearances have opened up. This is one cause of the ticking sound.
I hope this is a wrong diagnosis, but if it's correct, then your engine needs to be pulled apart and all of the bits of metal from the worn camshaft will have to be cleaned out. Then you will need to put in a new camshaft and lifters. If you ante up to put in a roller cam and lifter kit at this stage, then you can keep using an SM rated oil.
Regards from Down Under
aussiejohn
Old Jun 8, 2010 | 07:07 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Headers, no, I have the 69 style sidepipes.
Oil change, not recently, although I did notice the oil level was low and added some Mobil one synthetic (10w30) that I had in the garage.
How can I tell if it's a worn camshaft?
Old Jun 8, 2010 | 07:25 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
One new thing that has started to happen, the car has become more difficult to start when cold.
Don't know if that's related to a worn cam or not.
Old Jun 8, 2010 | 07:31 AM
73StreetRace's Avatar
73StreetRace
Did you check valve clearance ? Do you have hydraulic lifters ?
Old Jun 8, 2010 | 09:18 AM
aussiejohn's Avatar
aussiejohn
Moon,
You have answered your own question. Mobil One is not suited to engines with a flat tappet camshaft. It does not have the minimum required amount of ZDDP. Looks like a re-build and a new camshaft and lifters are coming up.. You MIGHT be lucky if you drain ALL of the oil out, including the filter, and fill up with an SG rated oil and a new filter. Good luck!
aussiejohn
Old Jun 8, 2010 | 09:45 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Valve clearance, no, but I have noise from both heads, and it doesn't seem to be specific to one area.
I will check this weekend.
Hydraulic lifters, don't know, this is my first SBC powered car.
It's a 1970 Corvette engine AFAIK.
Old Jun 8, 2010 | 09:46 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Originally Posted by aussiejohn
Moon,
aussiejohn
The oil change was done last fall, before I put it away, regular Castrol 10w30.
Ok, I've drained all the oil, new filter and put in Mobil 1 15w50 synthetic (from the flat tappet thread).
Jerome
Old Jun 8, 2010 | 01:20 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Yes, hydraulic lifters.
Old Jun 8, 2010 | 02:55 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Valve lash. Sounds like you may have a rocker on each side a little loose.
Old Jun 8, 2010 | 08:07 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Did someone say ticking? Hopefully you know your friends and have no enemas.
Old Jun 9, 2010 | 01:25 AM
73StreetRace
That was my first guess... and IMO it's the first thing the OP has to check out
Old Jun 10, 2010 | 12:49 AM
Goody's Avatar
Goody
Remove the valve cover and have a look at the engine at idle. Are all the rockers moving the same distance up and down? You may need to do this a bit quick to keep the oil mess to a minimum.
If you carefully apply a little pressure to one does the noise go away?
A few things to look for: a broken valve spring, no oil coming out of the pushrod, a stud that is pulling out
To ticking?
