Decipher 1976 Vette Engine Codes
Old Mar 20, 2002 | 01:39 PM
Jim Shea's Avatar
Jim Shea
Default Decipher 1976 Vette Engine Codes
Could someone please decipher the following 1976 Corvette engine suffixes?
CLM, CLR, CLS, CHC, CHR, CKC, CKW, CKX
My 1984 edition of the Corvette Black Book doesn't break them down.
Thanx,
Jim Shea
Old Mar 20, 2002 | 02:13 PM
ROD NOCK's Avatar
ROD NOCK
Default Re: Decipher 1976 Vette Engine Codes (Jim Shea)
JIm-
The '02 book shows only the following for '76 suffix:
CHC: 350ci, 210hp mt CKX: 350ci, 180hp at
CKC: 350ci, 210hp at CLS: 350ci, 180hp at ce
CKW: 350ci, 180hp mt
Hope this helps out -Rod :chevy
Old Mar 20, 2002 | 02:22 PM
verskel's Avatar
verskel
If you can wait a few hrs.... I'll get my Corvette by the Numbers book from home at lunch time (which is now :eek: )
....It lists all the suffix codes :D
Old Mar 20, 2002 | 02:28 PM
verskel's Avatar
verskel
You're in luck (man, I love the internet)....here ya go :
1976 CLM 350 a/t L L48 185 4 Vette/Monte
1973 CLR 350 4 spd trans. T L82 250 4 Vette
1978 CLR 350 a/t, Calif L L48 175 4 Vette/Monte
1973 CLS 350 m/t, Calif T L82 250 4 Vette
1976 CLS 350 a/t, high altitude L L48 175 4 Vette
1975 CHC 350 m/t, h/p T L82 205 4 Vette
1976 CHC 350 m/t, h/p X L82 210 4 Vette
1975 CHR 350 a/t, s h/p, Calif T L82 205 4 Vette/Camaro
1975 CKC 350 a/t, s h/p, w/fed T L82 205 4 Vette
1976 CKC 350 a/t, s h/p, w/fed X L82 210 4 Vette
1976 CKW 350 m/t L L48 180 4 Vette
1976 CKX 350 a/t L L48 180 4 Vette
Here's the site in case I left out one : http://www.nastyz28.com/sbchevy/spcode2.html
:hat
Old Mar 20, 2002 | 02:45 PM
Tom73's Avatar
Tom73
CLM
1973 350/245hp 4 spd,Calif Z28
1976 350/185hp a/t Monte Carlo
CLR
1973 350/250hp 4 spd trans. L82
1978 350/175hp a/t, Calif L48 Vette
CLS
1973 350/250hp m/t, Calif T L82 Vette
1976 350/175hp a/t, high altitude L48 Vette
CHC
1973 307 tur hydro, Calif NB2 F, B, & X bodies
1975 350/205hp m/t L82 Vette
1976 350/210hp m/t L82 Vette
1980 350 auto trans. in full size
CHR
1975 350/205hp a/t Calif L82 Vette
1978 350/170hp auto trans. Camaro
CKC
1973 350/145hp m/t A & X bodies
1975 350/205 a/t L82 Vette
1976 350/210hp a/t L82 Vette
CKW
1972 350/200hp 4 spd trans. Vette
1973 350/145hp t/h F & X bodies
1976 350/180hp m/t Vette
CKX
1972 350/200hp t/h Vette
1973 350/145hp t/h Camaro
tom...
[Modified by Tom73, 1:35 PM 3/20/2002]
Old Mar 20, 2002 | 03:27 PM
Jim Shea's Avatar
Jim Shea
Thanx,
Just what I needed. I am sending an eMail to Corvette Fever correcting their May 2002 issue which has an article under SHARKbites on 1976 4-speed Vettes. Both the L48 and the L82 were available with 4-speed manual transmissions.
JIML82
Old Mar 20, 2002 | 03:37 PM
Tom73's Avatar
Tom73
Jim,
Before you get that out, were they talking about the close-ratio M21 and the L82. Per the Corvette Black Book, the M21 required the L82. Thus the M21 was not available with the L48.
You could get both engines with the wide-ratio 4-speed but only the L82 with the close-ratio M21.
tom...
[Modified by Tom73, 1:42 PM 3/20/2002]
Old Mar 20, 2002 | 05:09 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Decipher 1976 Vette Engine Codes (Tom73)
Yes, I just read that too. I think Sal Carbone meant to say "M-21 was required with L-82". The reader that wrote in however, said his car had an L-48 in it. Showed it in his VIN too. Then Sal went onto say, "Since your car has an L-48 in it, it had to have come with an automatic." Made it sound like there were no L-48 4spd(M-20) cars built in '76. :lol:
Old Mar 21, 2002 | 09:09 AM
Jim Shea's Avatar
Jim Shea
Default Re: Decipher 1976 Vette Engine Codes (Paul Borowski)
Thanks for the clarification on the close ratio versus wide ratio. I had already sent off the eMail to CF. It will be interesting to get an answer from them.
Now, I need to clarify some issues in their article about "rag joint R&R".
Jim Shea
Old Mar 21, 2002 | 09:14 AM
Tom73's Avatar
Tom73
That would be a long article, "remove old, install new". :rolleyes: :rolleyes:
tom...
Old Mar 21, 2002 | 10:28 AM
Jim Shea's Avatar
Jim Shea
It concerns me that they are prying on the lower end of the steering column in order to get clearance to remove the flexible coupling. I think that they are actually collapsing the steering shaft back into the steering column. It is not a safety issue but a collapsed steering shaft can start to have lash over time.
The shaft is actually two pieces. They are flatted where they come together inside the column. The area where they are flatted and engaged with each other is actually injected with molten plastic at the factory to "lock" them together under normal driving. However, under a severe front end collision, the plastic shears and the two shafts telescope onto each other. It is that plastic injected joint that is being sheared when the lower end of the column is compressed.
Also they make no mention of checking to be sure that the stop pins are central in the column flange slots. The plastic spacers are on the replacement flexible coupling to help align everything as you are assembling the steering column to the steering gear. You are supposed to pull the spacers and throw them away after you button everything up. (You can grip the spacers with a hook (like a coat hanger) and pull them straight off.)
To Decipher 1976 Vette Engine Codes
