Electrical gremlins.
Old Jun 8, 2010 | 08:32 PM
Grumpy 427's Avatar
Grumpy 427
Default Electrical gremlins.
Well i connected up the battery today for the first time since the car has come apart. So far the dash lights dont dim, and the high beams wont come on.? I will order a headlight switch, that should fix the dash light issue, but where do i start looking for the high beam brights?
On a plus side, the stereo works and so does the power antena.
Old Jun 8, 2010 | 11:00 PM
wombvette's Avatar
wombvette
Dimmer switch
Old Jun 9, 2010 | 12:30 AM
Grumpy 427's Avatar
Grumpy 427
That would be the signal light lever on the column. Where is the relay or switch located?
Old Jun 9, 2010 | 01:24 AM
Grumpy 427's Avatar
Grumpy 427
Wilcox any help? lolol
Old Jun 9, 2010 | 06:41 AM
...Roger...'s Avatar
...Roger...
Before replacing the dimmer switch check it. When you operate the dimmer does the blue high beam indicator in the dash come on ?
Its not unusual for both high beams to be burned out.
Old Jun 9, 2010 | 07:43 AM
Chef-Greg's Avatar
Chef-Greg
Cruising
Same problem with mine when i bought her. We chased the wires to the headlight switch and found when the last owner pluged the switch back in he bent two of the connectors which didnt make contact anymore. straightened them up and everything worked. just check your connections first.
Old Jun 9, 2010 | 09:34 AM
Grumpy 427's Avatar
Grumpy 427
Hey Roger, the high beam dash light does not come on either.
Old Jun 9, 2010 | 09:53 AM
...Roger...
Thats another sign the power is not coming through the dimmer switch.
Old Jun 9, 2010 | 10:03 AM
Grumpy 427's Avatar
Grumpy 427
ok just got back in from the garage, and now the damn thing is working? I went from low to high 2 times now it works every time. My dash lights still wont dim, so i will order a new head light switch, but do i just call it good on the low / high beams?
Old Jun 9, 2010 | 10:29 AM
...Roger...
I would,probably just needed worked a few times. 4 way flashers do the same thing if they aren't used occasionally.
If you can get to the plug make sure its on OK,if its loose it can cause the connector to get hot.
Old Jun 9, 2010 | 10:34 AM
Danish Shark's Avatar
Danish Shark
Don't know if the switch is still the foot operated one for your year but if it is:
Is the carpet in? I had the same problem with no high beam, turned out the carpet was to tight over the switch, it felt like it switched but it didn't!
Old Jun 10, 2010 | 09:55 PM
Grumpy 427's Avatar
Grumpy 427
Ordered new light switch today, should solve problems.
To Electrical gremlins.
