200-4r transgo kit...
Old Jun 9, 2010 | 01:35 PM
glarior's Avatar
glarior
Default 200-4r transgo kit...
I have a 200-4r and transgo reprogram kit for my 80vette. Anyone know how many check ***** they put back in it?
Also, anyone have a diagram for the valve body?
Old Jun 9, 2010 | 08:06 PM
glarior's Avatar
glarior
bump
Old Jun 10, 2010 | 06:24 PM
TimAT's Avatar
TimAT
Trans-Go normally has a pretty good instruction sheet in their kits. Last one I did had both diagrams of the valve body and case showing where the check ***** fit, and a diagram of the spacer plate showing what holes need to be drilled or plugged.
When you start changing the springs in the valve body, I'd recommend doing one at a time, go slowly, and cover the valve as you remove it with a rag- sometimes the valves will pop out and could go flying across the shop. Not enough force to hurt, but it's a PITA trying to find the parts, and then trying to figure out exactly which direction the sleeve/piston goes back in.
Old Jun 11, 2010 | 12:09 PM
glarior's Avatar
glarior
Ya, I changed the springs one by one. I am down to installing the check ***** in the transmission and valve body. A little confused on the plate and gasket that goes on it. I have to figure it out... I will get it done sooner or later lol
Thanks for the reply
Old Jun 11, 2010 | 02:35 PM
TimAT's Avatar
TimAT
Use some vaseline to hold the checkballs in place. One of the gaskets for the spacer plate will have "VB" cut into it, usually toward the rear (pointy end). or maybe one will have "CS", I've seen both.
To 200-4r transgo kit...
