72 sb carb plumbing
Old Jun 8, 2010 | 07:36 PM
tgensel's Avatar
tgensel
Default 72 sb carb plumbing
Anyone have have any pics of oem carb vacuum plumbing?
Old Jun 9, 2010 | 01:22 PM
z10kl's Avatar
z10kl
I would like to see this also. TTT
Old Jun 9, 2010 | 04:45 PM
Alan 71's Avatar
Alan 71
Hi,
Since no one with a 72 spoke up I'll try to explain using my 71.
REMEMBER the 72 has the TCS solenoid mounted on the right side of the intake manifold just to the rear of the choke coil; NOT where the 71solenoid is mounted.
The 2 hoses from the pcv valve(large) and the charcoal canister (small) go to the same nipples as shown on my 71. The hose from the distributor goes to the SIDE nipple on your 72 solenoid and a hose comes off the FRONT nipple of the 72 solenoid and runs to a nipple on the carburetor below the choke take-off.
That's it! Just 4 hoses.
Regards,
Alan
Old Jun 9, 2010 | 07:44 PM
tgensel's Avatar
tgensel
Thanks Alan! Boy thats a beautiful engine Bay!!
ba
Old Jun 10, 2010 | 12:23 PM
Mashman's Avatar
Mashman
Originally Posted by Alan 71
Hi,
Regards,
Alan
Hi Alan,
Nice pitures!
I'm a little confused though, I thought the source for the vacuum advance/TCS is the vacuum source that runs thru the tube that goes thru the choke pulloff linkage?
*EDIT* Sorry - after posting I read your post (should have done that first!), and I see you explain the difference. Sorry about that!
Thanks,
Matt
Old Jun 10, 2010 | 03:16 PM
Alan 71's Avatar
Alan 71
Hi Matt,
It IS confusing because 70, 71, and 72, are all different; with 70 and 72being a BIT similar!
Regards,
Alan
Old Jun 10, 2010 | 10:28 PM
vettes4evr's Avatar
vettes4evr
I'd like to see both close up shots of the carb for a 72 LT-1. I'm about to install the TCS & idle stop solenoids on mine.
Old Jun 11, 2010 | 03:53 PM
Alan 71's Avatar
Alan 71
Hi v4e,
I believe Forum member War Bonnet has a 72 LT-!.
Perhaps a PM will get you a couple of pictures?
Regards,
Alan
To 72 sb carb plumbing
