lowering
The rear is lowered by 10 inch bolts, cut down to 9 inch, and maxed out on threads. The bolts are C4 lowering bolts from VBP.
No issues here with that set-up and rides very nicely.
My wheels all around only have 3.75 inch backspace, instead of the OEM 4.00 inch, so Ive gained 1/4 inch clearance, which is useful in the back to keep the bolt away from the rear tires inside sidewall.
Never heard of a VBP drop spindle for C3 Corvettes.
B.
If that's not low enough, dropped front spindles would then be the way to go, but there are still issues out back which have to be considered.
FWIW, VBP's 550# front coils usually drop the front ~1" from standard ride height. However, cutting springs is NOT necessarily a bad thing (
). It does raise the effective spring rate, but you can do it without using a torch (carbide blade works great). That said, without a suitable tire/wheel combo ride height changes won't solve every fender to tire gap problem.
TSW
edit - MN-Brent you might want to think about a clipped main leaf.
If anything, I'm going 18s in the rear, same as Motorheads set-up! I hoping he'll tire of his combo and sell me his rollers!
My Dunlops are 6 yrs old now and gettin' a little slippery.
LOOKS GOOD THOUGH--
