Headers installed - OK to leave this as is?
Old Jun 10, 2010 | 07:51 AM
81_vette!'s Avatar
81_vette!
Default Headers installed - OK to leave this as is?
Should this be filtered, blocked off or just left alone?
Other than sucking in hot air, any issues I should be considering?
As always - thanks a million for your time.
Old Jun 10, 2010 | 07:58 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
If you remove the vacuum source the internal flapper stay closed so you won't be sucking in hot air.
Old Jun 10, 2010 | 10:12 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
You can make it functional again just by putting the adapter pipe on the headers for the hot air tube to mate to.
Old Jun 10, 2010 | 11:19 AM
7T1vette's Avatar
7T1vette
Just rig the air cleaner so that the airvalve on the inlet pipe is fixed in the "open" position. Then you can cap that tube off or remove it altogether.
To Headers installed - OK to leave this as is?
