68 Transistor distributor question!!
Old Jun 10, 2010 | 06:05 PM
whitehause's Avatar
whitehause
Default 68 Transistor distributor question!!
I'm getting ready to fire up my newly rebuilt 454, and I came upon a bit of a quandary. All the original ignition equipment is being reused, and I'm not sure where to set the #1 spark plug wire on the distributor. In the book it says that (looking from the back of the motor) with points it should be at 1:00 and with HEI(coil in cap) it should be at 11:00. The transistor Ign falls in the middle of this. It doesn't have points, but it does have a separate coil similar to a points Ign. SO.....which position should I use? I assume that if the wires are on correctly it wouldn't really matter, but I'm not sure.
Any help with this would be greatly appreciated!
Old Jun 10, 2010 | 06:10 PM
TimAT's Avatar
TimAT
Set it just as you would a points type ignition. All you need is room for both the tach cable and the vacuum advance can to be able to adjust timing and not either kink the tach cable or hit anything with the advance can.
