The other day while driving my 1977 Corvette, I noticed the temp gauge needle fluctuating rapidly. Before this the gauge worked fine.
Upon returning home the gauge stopped working. The needle is resting in the lowermost position which is about 100 degrees.
Up to now I have replaced the sending unit. This did not work.
Then I grounded the wire that connects to the sending unit to the block while the ignition was in the on position. No movement.
Before I proceed further can someone advise me on what to do next?
My next move was to remove the center gauge cluster. But this appears to be a big job and I am not sure how to do it. The only thing I can think of is that maybe one of the wires on the back of the gauge fell off or something to that effect. I think the gauge is still good because the needle is in the lowest part as if the car is turned off.
If I do need to remove the center cluster, can someone advise me on how to do it?
Any help is greatly appreciated. Do not want to drive the car without a temp gauge.
Ignition ON, engine OFF: remove wire from sender (OPEN circuit) and meter needle should be at one end of the scale; ground the sender wire to the block (SHORT circuit) and meter needle should be at the other end of the scale. If that test works OK, then the meter is fine. If that test shows no needle movement, then one of two things is your problem: the 12v. line to the gauge has had a break in it (or bad connection); the meter circuit has failed--probably a termination connection on a fine coil wire has fatigued.
The fluttering you saw on the gauge was the [defective] wire [wherever it turns out to be] finally losing its 'grip' and breaking the connection. My 'guess' is that the 12v. power feed to the gauge was lost.
Just did the test as described above. Turned ignition on, engine off. With wire on sending unit gauge was at lowest level. Disconnected wire and shorted to block, no movement.
Put a digital voltmeter across gauge at rear of gauge. Meter read -17 volts!!! I measured at the three o'clock and nine o'clock positions.
Where in the world did you get that picture above,thats about as wrong as you can get.
Go to the Willcox site and to the help section , he has an accurate pic with the proper washers and all.
Roger thanks for the heads up. I found a picture on the wilcox website and I think I found the problem. It appears to be a break in the wire from the sending unit to the gauge.
This is what I did.
At the back of the gauge I shorted the ground and temperature gauge sender terminal. The gauge moved to the uppermost position.
Then just to satisfy my curiosity...
I connected a wire to the engine block and ran it to the back of the gauge on the temperature gauge sending unit terminal. Once again the gauge needle moved from the lowermost position to the uppermost position.
Therefore, it appears that there is a break in the wire from the engine compartment.
You made a good diagnosis. It appears to be a break in the sensor signal line [based on your results]. A 'failed' foil line on the circuit board or a broken sensor wire are the possible culprits.
Ooglie.. ping the wire for continuity from the cluster plug in to the end where it connects to the gauge. My bet and from what you described is that the sending unit wire is broken. Check right at where the wire runs in to the main harness and you'll have to have a tester you can pierce the wire with. Not a big deal but you should be able to find your short.
With the needle resting on the 100 degree position it sure sounds like you are missing input ohms to the gauge.
If you grounded out the gauge and and received a hot temperature then it also appears as if the gauge is working just fine!
I'll be online later tonight too.. but here is the picture Roger is talking about.
Hey gentlemen I am having a similar issue on my 74', when i key on the power the needle on the gauge jumps a bit, so I know its getting power. I replaced my sending unit and the wire from the unit to the gauge. Still I have no response from my temp gauge other than the flick on power. Was considering sending it into Ecklers for their gauge restoration service... but could it be anything else. Or am i right in guessing that my gauge is bad?
Well, it turns out it was the plug that connects to the sending unit. Im not sure what its called. I replaced it temporarily with a blade type connector and the gauge works now. I need to get one of those plugs.
Raider...
My guess is that it is not the gauge but a continuity problem from the sending unit to the gauge. I went through the trouble of removing the gauge cluster and conducting a few tests with the back of the gauge exposed. Without removing the gauge cluster and grounding the sending unit wire, I saw no movement in the gauge. Since I did remove the cluster I was able to see the gauge was working.
This allowed me to narrow down the break in the circuit.
