motor mounts
Old Jun 13, 2010 | 11:37 PM
79c3man's Avatar
79c3man
Default motor mounts
should I use safety or non safety motor mounts for a 79 corvette ,what is the difference
Old Jun 14, 2010 | 03:20 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
stock motor ? if yes ... doesn't matter you don't have enough torq to break a mount !
actully you would want the interlocking mount, the design keeps the mount from literally falling apart. if it fails.
Old Jun 14, 2010 | 06:35 PM
vettehardt's Avatar
vettehardt
Not true. I just had to replace the drivers side mount on my stock 190hp '76 motor. It came appart and the alt. arm was hitting the hood. I have been autocrossing the car since august last year. I believe it broke in september though and I didnt' find it was broken untill April.
The interlocing (safety) type mounts are what i put into mine. It will keep the motor from lifting up too much when the mount does break.
Old Jun 14, 2010 | 07:41 PM
GUSTO14's Avatar
GUSTO14
Default Motor Mounts Locking-vs-Original
In case you didn't see this post, here's a bit more on the SB motor mounts...
http://forums.corvetteforum.com/c1-a...-original.html
Good luck... GUSTO
To motor mounts
