81 no electrical power
Old Jun 14, 2010 | 09:43 PM
chuck81's Avatar
chuck81
1st Gear
Default 81 no electrical power
had to replace fuse on my 81 for radio. I did, now I have zilch when turn ignition. absolutely no power anywhere. Battery is fine. obviously ignition switch I'm guessing? Is there something I'm missing? I'm a big guy, so I'm worried I may have accidently done something under dash at panel. any help would be great.
Old Jun 14, 2010 | 11:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Got to go thru the basics: Check for power at the starter on the big cable and then the fuse links, there are 3 of them there. Its a piece of wire spliced onto the wire harness that acts like a slow fuse. Battery cables are a common place for problems, bad connector, loose cable etc..
Old Jun 14, 2010 | 11:05 PM
dburgjohn's Avatar
dburgjohn
there should be power at some of the fuses even if the switch is off. did you check other fuses with meter or light? Are your battery terminals clean?
To 81 no electrical power
