Question on PCV Setup
Old Jun 26, 2020 | 10:34 PM
KenSny's Avatar
KenSny
Better yet, why don't you start a new thread so we don't have to read through stuff from 10 years ago.
Old Jun 27, 2020 | 10:33 AM
Rob Via's Avatar
Rob Via
Lack of vacuum is from the large cam.
Old Jun 27, 2020 | 12:29 PM
MelWff's Avatar
MelWff
Try to find a CV746C PCV valve
Old Jun 27, 2020 | 01:36 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Test it with a vacuum gauge and tell us what the vacuum is at idle.
10" ?
14" ?
18" ?
Old Jun 27, 2020 | 03:14 PM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by Rob Via
Resurrecting a very old thread, but I have a question.
I read enough that I understand getting the airflow through the crankcase. Pull from one valve cover through the engine and from the other vented (maybe filtered) valve cover.
What about high HP motors that don't make much vacuum? I have to rev the motor a little on mine to build enough vacuum to move the lights. I don't think there is a leak in the canister, but maybe there is. Typically one light moves and then after a little rev, the other light moves. If I'm not really putting much pull on the PCV valve most of the time, is it really pulling air properly? Does the PCV system need much vacuum to work? If it doesn't I could see the PCV valve starving the vacuum down most of the time and even an engine without much vacuum would function OK. But I don't know how much vacuum it really needs.
10 years later, it’s time to ask your question in a new thread.
