Torque converters
Old Jun 17, 2010 | 11:55 AM
Mick 72's Avatar
Mick 72
Default Torque converters
Will a converter from a TH350 fit a TH400. I see in summit and jegs they list 350/375/400. If so, can you tell by looking at the converter what stall it may be. Reason I'm asking I have a 2300 stall in my TH400 now but I have a TH350 and converter just sitting around. I'm thinking about maybe going up to 2700 or 3000 stall.
Old Jun 17, 2010 | 12:38 PM
mrvette's Avatar
mrvette
I presume you are aware that running a 'drag race special' high stall converter on the street will tend to make the tranny run hotter'n hell in the summer, you will need a LARGE extra cooler,....
much less the MPG loss....but for a digger, have fun....
Old Jun 17, 2010 | 01:08 PM
Mick 72's Avatar
Mick 72
That was going to be my next question. Going to that high a stall what will be the effects of regular drivability? I have just replaced the rear gear set with a 3.55 and the cam I have is the comp cam 274 which is rated for 1800-6000 with a holley street dominator single plane with a jet performance stage 2 q-jet. I plan on driving to Carlisle at some point and myrtle beach and pigeon forge. I'm running a good size cooler already.
Old Jun 17, 2010 | 03:47 PM
ajrothm's Avatar
ajrothm
As long as the new converter is of decent quality(ie. Not the local speed shop special) and is clean inside you should be good to go. Those 3.55s will tighten the converter up quite a bit. With that cam/intake setup, you definetly need more converter. If the converter is a good one(Ati, Coan, Yank, PTC, Precision Industries etc) it will be very efficient around town and tight on the highway....they will only get loose when you start putting your foot in it. Less throttle, less torque= less slippage.
My converter is a custom from a local guy, "tight" 10"... I can barely tell there is a stall in it at all around town. Hwy rpms only went up about 200 at 70mph....but it will flash to 3700rpms from a 1500 rpm stomp.....I only have 3.08 gears also.
If your other converter is a cheapy with unknown origin, I would wait until you can get a good one....it makes all the difference in the world. My next converter will be an ATI treemaster. And I drive my car everywhere...
Old Jun 17, 2010 | 05:28 PM
Mick 72's Avatar
Mick 72
Thanks!!!
Old Jun 17, 2010 | 06:44 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Yes....to orginal question...they interchange between T-350 and T-400 assuming the T-350 is a *non-lockup* trans.
2700 isn't too much stall. But as mentioned...there are big differences between converters. You can't really tell from the outside. Many variations of 12", 11" 10" 9.5" etc converters.
Alan...I had one built years ago by Brittain transmissions off the Hardy Toll Rd. Did a GREAT job...hit my goals first try and it is still working today!
JIM
Old Jun 17, 2010 | 10:02 PM
JohnnyLT1Runner's Avatar
JohnnyLT1Runner
There is no way of telling stall size even if you cut it open. Stay away from cheap converters, they often have adapter rings welded on to fit your flexplate. Go with a billet converter if they have them available from summit or jegs.
Old Jun 21, 2010 | 08:06 AM
Mick 72's Avatar
Mick 72
Are the higher stall converters all smaller than factory. The 2300 that I have is bigger than the one I have with the TH350. Would that mean that it's "is" a higher stall. I know guy I got the transmission from and we both get ours built from the same guy so I'm not worried about the quality of the converter I'm just curious how I can find out what it is without having to put it in the car and then, if it's not what I want having to pull it out again.
Old Jun 21, 2010 | 10:13 AM
ajrothm's Avatar
ajrothm
You can get different stall speeds in different size cases. It's all in how it was built. You could have a 3000 stall in a 12" converter or a 9.5"....
Usually, if the converter is built by a reputable company, smaller the case, higher the stall speed. Very generally speaking, normally a 2800-3500 range converter is in a 10" case. They are normally more efficient. But in the converter game, there are so many variables it's not even funny. Converter builders can increase stall speed several different ways when building a converter and some of these methods kill efficiency....they are loose, sloppy around town and lose trap speed in the 1/4.
Just do your homework on converters. The good thing is if you don't like it, you can pull it out. But I would spend $500'and get a custom built converter for your combo and do it right the first time.
Old Jun 21, 2010 | 05:18 PM
Mick 72's Avatar
Mick 72
Thanks, I think that's what I'll do!
To Torque converters
