Headlight switch replacement
Old Jun 21, 2010 | 07:37 AM
Kap142's Avatar
Kap142
Default Headlight switch replacement
How much of a PITA is replacing the headlight switch on a 72 C3. I guess what I'm really asking is how difficult is it to get the drivers side of the dash removed or open enought to get to the switch?
Old Jun 21, 2010 | 08:41 AM
...Roger...'s Avatar
...Roger...
Here is the way I do it. Remove battery cable, remove all the upper dash screws , all the center cluster screws,the 2 screws inside the drivers door jamb,unscrew the tach cable at the distributor,remove the 2 bolts holding the column up, loosen the 2 bolts going through firewall holding bottom of the column,loosen the cinch bolt above the rag joint,carefully work the tach/speedo cluster out , remove electrical connector ,pull the headlight **** out-remove hand from ****-press release button on switch-pull **** out and free,unscrew slotted nut the ****/shaft went through,remove switch. Probably missed a few items but hopefully you get the idea. Would that be considered a PITA ? Yes it is but not horrible.
Old Jun 21, 2010 | 08:47 AM
Kap142's Avatar
Kap142
Thanks Roger, that's exactly what I needed. Just waiting on the new switch to arrive now.
Ken
Old Jun 21, 2010 | 04:17 PM
Alan 71's Avatar
Alan 71
Hi Ken,
Roger's instructions are RIGHT ON!!!!
I'll only add to be VERY careful with the dash pad because if it's an original they've become pretty brittle from age and only make a gentle 'pop' when the break from too much much pressure!
Regards,
Alan
PS: Almost forgot... take note of the position of the 2 vacuum hoses (blue stripe and black) on the original switch so you put them on the new switch correctly.
Old Jun 21, 2010 | 04:23 PM
jostby's Avatar
jostby
I'm going to replace just the headlamp **** (and stem of course) but not the switch. Is it possible to get to the back side of the switch to release the **** without pulling everything described?
Old Jun 22, 2010 | 08:40 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
I could not get to mine without pulling the dash pad as explained. I had the seat out and was laying down on the floor and still could not even see the switch. Just follow the instructions and it's not that hard. I only loosened the two bolts that hold the column under the dash and removed all the screws in the lower dash pad, pulled out the corner and removed the switch.
Old Jun 22, 2010 | 08:49 AM
...Roger...
The only reason I loosen so much is to allow more flexibility because these old dashes are pretty brittle as Alan posted. Its very possible to break the metal center cluster housing in the area it's designed to break if you get thigs in a bind.
As a younger man I used to be able to get my hand up from under the dash and release the headlight switch ****.
To Headlight switch replacement
