zz4 power upgrade
Old Jun 23, 2010 | 09:53 PM
KWIL's Avatar
KWIL
St. Jude Donor '12-'13
Default zz4 power upgrade
I am thinking the following upgrade to my ZZ4 in my 80:
http://popularhotrodding.automotive....ld/index1.html
I don't really want to change the heads so I think I would stop after stage 3.
Question 1: PHR used an Edelbrock Air Gap intake which does not fit under a stock C3 hood, from what I read. I really don't want to have to buy a new hood and have it painted. Is there is similar intake that would fit under the stock hood? Or would the ZZ4 intake work about as well?
Question 2: Has anyone done this upgrade or a similar one, and if so, did you achieve similar results?
Old Jun 23, 2010 | 11:45 PM
jackson's Avatar
jackson
recognise baseline was 344
hi-ratio rockers made 16 more
bigcam2 w/ springs&retainers & intake made 48 more (total 408)
all that for about 60-65 more hp? about 18% increase. poor roi
me thinks stock rockers, stock intake, ported zz4 heads & good cam & good springs will make +400.
L98/ZZ4 heads are good up to a point .... but they have relatively small intake port volume coupled with not so advanced comb chamber design. They can be ported but that's more dough. If you're looking to make much more than 400 hp ... suggest first swap to heads w/ good springs & bigger cam first.
stock zz4 intake man will flow about all zz4 heads can be coaxed to flow. Intake ain't your bottleneck.
keep in mind, zz4 heads have Small 58cc comb chambers that make lotsa compression. Some but Few aftermarket heads are less than 64cc ... be prepared to lose a good half-point of comp.
& keep all this in perspective ... PHR is hawking parts for their advertizers ... & you (nor they) sure don't need $118 pushrods for this .
Old Jun 24, 2010 | 08:03 AM
KWIL's Avatar
KWIL
Thanks for the info. Any specific cam and head suggestions?
Any one else have any input?
Old Jun 24, 2010 | 08:08 AM
KWIL's Avatar
KWIL
Interesting. Do others concur? Do you think their HP numbers are suspect as well?
Old Jun 24, 2010 | 09:00 AM
ZZ71S's Avatar
ZZ71S
Have you seen the Lt 4 hot cam mod all you need is the cam 1.6 rockers and a Edlebrock RPM preformer 395 hp
Old Jun 24, 2010 | 01:37 PM
69vettester's Avatar
69vettester
I agree with Jackson.
That isn't a real good Bang for the Buck write up, especially the head swap part
You can get those beehive springs and change them yourself on your 58cc aluminum heads, then go up 2 notches with a comp HR cam.
I think you will have enough play with a new head gasket thickness to get a 10:1 CR.
The Airgap manifold may be worth a little gain?
For under 1K$ you should be at 375HP. With some porting on the zz4 heads, maybe 400+.
An air gap should fit under your hood with a dropbase canister, the airgap RPM would be a little to Tall.
Old Jun 24, 2010 | 02:35 PM
KWIL's Avatar
KWIL
For under 1K$ you should be at 375HP. With some porting on the zz4 heads, definitely 400+.
Pace has a kit claiming 408 HP for under a grand. http://paceperformance.com/index.asp...&ProdID=229106 (The HP claimed is achieved w/ a differant intake, however.)
I think if I just get the beehive springs, comp HR cam, and have the ZZ4 heads ported, I would end up spending over $1000, right?
I guess I'm just trying to find the most economical route to over 400 hp.
I hear there is still a market for ZZ4 heads, so I *may* consider selling mine and going with some better flowing ones.
Old Jun 24, 2010 | 04:10 PM
ZZ71S's Avatar
ZZ71S
You could always build a ZZ430 cloan Gm fast burn heads lt4 hot cam 1.6 rockers and Edlebrock performer rpm makes 430 hp Google zz430 all kinds of info on it out there
Old Jun 24, 2010 | 04:33 PM
FKING1's Avatar
FKING1
There was an article in the Feb. 09 "Hot Rod" that gives a number of upgrades to a ZZ4 getting to 430HP.
Old Jun 24, 2010 | 05:45 PM
69vettester
[QUOTE=KWIL;1574495834]Pace has a kit claiming 408 HP for under a grand. http://paceperformance.com/index.asp...&ProdID=229106 (The HP claimed is achieved w/ a differant intake, however.)
QUOTE]
A worthy porting of your heads would put the total cost to around $1200-1400 thats a good deal, to get your allready HiPer engine to possibly 400HP?
Keep in mind, 400hp is alot harder to get with a 350 than a 383 thats for certain.
I would feel Ive reached the tops with a reliable zz4 street machine by getting 375HP. with the cam upgrade, springs, and a real nice Port Job. Youd be going radical to expect 400+. ZZ383 is in that world
Also...
Im not so sure about putting 195cc or 200cc heads on your 350ci. May defeat your potential? Maybe someone who knows more about what it takes for a 350ci to run with 200cc intake runners will chime in?
Old Jun 24, 2010 | 09:34 PM
KWIL's Avatar
KWIL
http://www.hotrod.com/techarticles/e...ons/index.html
Looks like there are a few ways to skin a cat.
I'm hoping someone on CF has actually done some of these mods on a ZZ4 and can offer some insight/ advice.
Old Jun 24, 2010 | 11:13 PM
eagle275's Avatar
eagle275
hmmmm..good info.
Old Jun 25, 2010 | 12:04 AM
KWIL's Avatar
KWIL
Originally Posted by eagle275
hmmmm
Old Jun 25, 2010 | 12:18 AM
eagle275's Avatar
eagle275
Originally Posted by KWIL
Thinking about upgrades - like what I read. What's up with you? Been chasing any armadillos lately?
Old Jun 25, 2010 | 12:31 AM
KWIL's Avatar
KWIL
Sorry that I did not read into your cryptic message before you edited it.
Oh, I get it. There are armadillos in TX, and I live in TX. That's quite clever.
Old Jun 25, 2010 | 12:39 AM
eagle275's Avatar
eagle275
I used to live not that far from El Paso - Alamogordo,NM. Used to go through Amarillo a couple of times a week driving a big truck after retiring from the military. I go through every now and then on a run to the West coast. I like Texas - great people.
Old Jun 25, 2010 | 07:55 AM
ZZ71S's Avatar
ZZ71S
I have a zz4 with AFR 180 eliminators,lt4 hot cam with 1.6 rockers and Edlebrock rpm performer
To zz4 power upgrade
Old Jun 25, 2010 | 08:02 AM
KWIL's Avatar
KWIL
Have you had your setup dyno'd? How do you like it?
Old Jun 25, 2010 | 08:29 AM
ZZ71S's Avatar
ZZ71S
It still sitting on the stand but its based on GMs zz430 just with smaller port AFr heads I had the chambers milled down to 62 cc on the AFR sight there are 2 engines that are simular they are makeing somewhere between 430 and 450 hp and both make 470 torque I hope I get somewhere close to this
Old Jun 25, 2010 | 12:06 PM
SteveG75's Avatar
SteveG75
Avoid the Thumpr cams. All show and no go.
Get some good AFR heads and bigger hyd roller and enjoy.
If you want to go radical, here is 520 hp @6600 rpm build up of a ZZ4.
http://www.carcraft.com/techarticles...ine/index.html
