'73 reverse light doesn't shut off
Old Jun 23, 2010 | 11:01 PM
lagnaf's Avatar
lagnaf
Default '73 reverse light doesn't shut off
Hey there folks...
I've got a '73 that all of a sudden the left side reverse light is on all the time and when I put it into reverse the right side doesn't turn on.
Any ideas?
Have I mentioned that I couldn't diagnose a lit candle?
Thanks.
Old Jun 23, 2010 | 11:40 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I'll start with one potential solution though I think you have two problems. Try the bulb from the reverse light that works in the one that doesn't. I suspect it will.
Is the car an auto or 4 speed?
Old Jun 23, 2010 | 11:46 PM
lagnaf's Avatar
lagnaf
It's a 4 speed.
Old Jun 24, 2010 | 06:18 AM
...Roger...'s Avatar
...Roger...
The right side bulb is probably burned out. Sounds like the reverse light switch is bad, misadjusted or the rod controlling it fell off.
Look under your hood at where your accelerator cable comes through and see if you can find a 2 wire plug with pink and green wires. Unplug it , the reverse lights should go off,if they do what I said above is most likely true.
Old Jun 24, 2010 | 06:22 AM
...Roger...
Here is a pic that shows the reverse light switch. The switch is hanging below the linkage and has 2 wires.
Old Jun 24, 2010 | 10:45 AM
lagnaf's Avatar
lagnaf
Wow... you disassembled your entire care just to show me two wires? You are awesome, dude!
Joking aside... thanks for the advice. I simply love this site.
Old Jun 25, 2010 | 08:35 AM
hwcoop's Avatar
hwcoop
no trouble at all
Old Jun 25, 2010 | 08:54 AM
...Roger...
Originally Posted by hwcoop
no trouble at all
Definitely a great pic to show for many situations,thanks hwcoop.
Here is the thread it was posted in.
http://forums.corvetteforum.com/c3-t...uncie-m21.html
To '73 reverse light doesn't shut off
