Has anyone had this problem??
Old Jun 25, 2010 | 12:12 AM
cu79vette's Avatar
cu79vette
Default Has anyone had this problem??
I have a '79 ... when I increase speed, as I approach about 40 to 45 mph, the rpms on my tachometer also increase accordingly. I typically don't go any faster than 45 to 50mph (under 4000rpm) until I figure this out. I ran at 60mph the other day just to see what the rpms read and it sat on 5000 rpm. If I continue to increase speed, the rpms would continue to increase.
Note: I dont think the tachometer or speedometer are malfunctioning. I had a vacuum leak that I recently fixed and no impact on this. The transmission does not seem to be malfunctioning but obviously could be an issue. The carburetor was replaced a few years ago and the car sat for several years afterwards. I'm not sure if this was an issue before the car sat or the carburetor was replaced.
Any thoughts?? Thanks.
Old Jun 25, 2010 | 05:33 AM
jotto's Avatar
jotto
Sounds like your tach board is faulty. My tach would read fine but just didnt seem to go with how the engine sounded.
At 60mph, I would have thought turning 5k rpm to be high.
What rear end and tyres do you have, also, was that in top gear?
Assuming a 3.7 rear, 27 inch tyres and a 1:1 ( top gear ) you should be around 2700rpm.
Check this out,
http://www.corvetteactioncenter.com/...gearcombo.html
as you can see from this vid, mine was reading about twice what it should have.
Old Jun 25, 2010 | 07:08 AM
...Roger...'s Avatar
...Roger...
Sounds like you have lost the vacuum to the trans modulator
Old Jun 26, 2010 | 10:28 PM
cu79vette's Avatar
cu79vette
Thanks for the replies. The vacuum line to the transmission vacuum modulator seems to be OK. I am going to try replacing the transmission vacuum modulator itself and see if that has an impact. After reading a few other threads about similar topics, replacing it is a good place to start.
Old Jun 27, 2010 | 07:24 PM
cu79vette's Avatar
cu79vette
I replaced the transmission vacuum modulator and that didn't resolve the problem. Inexpensive modification and one thing I can check off my root cause list. Thanks for the suggestions. Any other thoughts? :-)
Old Jun 27, 2010 | 07:30 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Is this an automatic ? Sounds like it is not shifting gears and staying in first
Old Jun 27, 2010 | 09:11 PM
...Roger...
Maybe the downshift cable is too tight.
Old Jun 27, 2010 | 10:53 PM
cu79vette's Avatar
cu79vette
MotorHead, the tran is an automatic. (My Mustang-loving father-in-law reminds me of it often.) It does appear to be shifting, just at rms way too high.
Roger, I will check the downshift cable. Any tips or recommendations with that. I have never had to adjust it.
I also need to check the tack as jotto recommended, just to be sure.
Old Jun 27, 2010 | 11:15 PM
drwet's Avatar
drwet
Can you connect another tach to see if your guage is reading correctly?
Old Jul 2, 2010 | 05:38 PM
cu79vette's Avatar
cu79vette
And the verdict is ... problem was the tach. It was reading double exactly like jotto's video. Replaced the tach and its good to go. This cleared up several questions but better yet, I can ride faster than 45mph!!.
Thanks everyone for your help. I should have asked this question a year ago! These forums are outstanding!
To Has anyone had this problem??
