Conversion to Tremec TKO 600 5-Speed?
The product is a Tremec 5-speed TKO 600 Elite Kit. This is when converting from automatic to manual vs. the Deluxe when converting old 4 speed manual to the 5 speed manual.
Two distributors were mentioned in this old thread; Classic Chevy 5-Speed and Hurst Driveline Conversions. Both have this product as well as what looks to be good customer service and maybe the best pricing for this kit??
Gordonm, ...Roger..., & sstocker31 seem to have experience with this conversion and I really want to find out more about it and this is where the old thread kind of stops and I have brought it up here.
Old thread that segways to starting this thread; http://forums.corvetteforum.com/c3-t...re-to-buy.html
I want to put the 600 5-speed in my 1978 possibly. It has the all stock motor and transmission. A new motor or building mine a bit may happen next summer but I would like to do the transmission this year. Much better for many reasons, including the fun factor for sure!
I'll leave it general here but some questions for you guys to consider for me please:
Is this a top notch product and good dollar value for this kind of an upgrade?
Is there another product considered to be any easier or higher quality to deal with? This looks like very few parts to deal with. Only a little crossmember work to make some more work room available now and removable for later too as I read it (as far as modification work goes).
The technical support looks fantastic for both but I mostly read that classic 5 link and I've copied here: http://www.classicchevy5speed.com/Default.aspx
Do these companies run specials, make deals, have sales, or offer incentives?
Would a guy need much more than what is in the package to complete the project? Probably the clutch pedal kit for sure
. They show some upgrades that are options but I don't know if they are good or needed or what?What sort of time for man hours would this take; rough guess. Consider one person is reasonably knowledgeable and the helper is me
. Seriously I have not done transmissions but this one looks mostly built after removing the old one. Usually harder than it looks though.Any suggestions from you guys that have done this kit or another one that you would recommend would be great! Seems like a great idea and not too far fetched to complete. I want minimal down time since I have not driven the car yet this year because of upgrading.
Thanks.
Greg
Their TKO-600 kit also includes the clutch disc, pressure plate, TO bearing and alignment tool along with all the other goodies.
Their ebay price is $3,350
http://cgi.ebay.com/ebaymotors/C1-C2...Q5fAccessories
A member here, who used to be a vendor carried/carries their solution and has several happy customers here.
They are on my short list for then I pull the trigger on this mod. Have been researching for ~1 year.
These kits are highly recomended by most guys here who have done the conversion. It totally transforms the car. I ran the 5 speed for a numbers of years and recently put in a T56 6 speed. Much more difficult to fit and hook up. The 5 speed is the way to go. Any specific questions just ask or PM me.
You will only get a TKO600 to fit with a 1310 series yoke, it's really tight around the transmission output because the TKO is about 2" longer than a Muncie.
It makes sense that the pedal box would have difficult access. I've been up under the driver's side dash a lot recently and it isn't pretty, or easy...
VERY kind of you to let me ask you questions in the future. I can assure you that I will. Is there a specific company out of all these that is particularly good to deal with from helpfulness to advice to patience with a guy whose strengths are not transmissions?
The Classic group seemed to have the owners as the hands on workers including tech support, not just sales....?
Thanks a lot Gordonm
It sounds like you're just saying that the wrong part got sent, it needs a different one to be correct. I assume they have the right u joints and are aware of this problem and which part(s) fit?
So what is the problem exactly, I don't see it nor has anyone else mentioned anything about it.
Could you be a little more specific, it would help me quite a bit because I don't understand.
Is this where some folks cut out a crossmember temporarily for room and then replace it with a modified version that is easily removed or replaced again. Something else I read that I don't understand yet...??
Really I need to know only one thing; is there a kit with all the right parts available that will work with my intended application?
Is this just the AMP place or everywhere that sells the kit. Confused.
I know Keisler and Classic have complete kits with everything you need. I have not dealt with Amp to see what their kit includes.
As for cutting the crossmember, you do not need to if your car is an automatic. It is already removeable and the kits come with a bracket that bolts the rear mount right to the existing crossmember.
"Driveshaft. Steel driveshaft complete with premium Spicer u-joints and custom 1310, strap style slip yoke. All driveshafts are balanced using state-of-the-art equipment."
It seems that this comes with what is needed...? I think anyway.
I also know it would be way funner to drive plus a bit more economical when doing some travel style driving.Of the 6 upgrades available on the web page that I'm referring to located at http://www.hurst-drivelines.com/inde...=67&Itemid=84# I think that maybe the competition street clutch would be a good upgrade, the pedal kit has to be an upgrade (from somewhere - it fits from here): flywheel or scattershield I don't know??
This site appears to be just as good as Hurst too. http://www.classicchevy5speed.com/im..._purchase.aspx
I'm guessing either is fine. I'm trying to find things that members can testify to having actual experience with; companies, people, or products.
Gordonm - that pedal box is mainly just 6 bolts at the firewall and some cable linkage that can be rigged before installation isn't it? Shouldn't be too bad, at least I could mostly see where I was working (mostly).
Can 2 people do that job in 2 days if they have never done it before? Within reason, doesn't matter, just will need to estimate time at some point.
Here is another option and it shows just the pedals. You can take out the box and remove the brake pedal and then put in the brake clutch combo. You have to get all the linkage, or you can go with a hydraulic setup (more money). I have done both. There are pluses and minuses to each.
http://www.keislerauto.com/vmchk/gm/...page_tabs.html
It would be a long 2 days but yes it could be done. A lift is going to make it a LOT easier and faster. I have done 2 with no lift and a few with a lift. I prefer the lift for sure.
I read a thread from March where you (Gordonm) were discussing Keisler and Tremec parting company. You were pro Keisler, maybe both rather equal, is that the same and how did that all sort out?
Saw another thread and they were really down on Keisler. Poor support, horrible shipping, no returned calls, lots of excuses, even missing a part or two. Sounded bad so I did not consider them before now...maybe. It was more than just one person and an isolated incident it seems to me.
I hope this all works out, very cool upgrade for another vette enthusiast in his early 50's!!
Remember, these cars were not built to tight specs. Anyone that has done any extensive work on them knows that. What works on one car may not work on another!
Corvettes are fairly well known for inconsistent fits over the years. Gaps and joints out of flush, etc. Minor is to be expected with these cars. Fiberglass moves over time and exposure to heat/cold and so forth.
Thanks for the reminder, Red 71. (fine looking car btw)
I would stick with Keisler and through my experience with them and with Gordon, he knows this trans and installations, he's the best in my book for getting advice on this topic, mine came out great...
So you like yours 73? Did you go from automatic to 5 speed or what?
Thanks for the testimonial on the product. Also for the testimonial on Gordon but I could tell that about him many posts ago in other threads!
