Help! Ball joints!
Old Mar 22, 2002 | 01:51 PM
Black68Vette's Avatar
Black68Vette
Default Help! Ball joints!
I'm having a deep problem breaking my balljoints loose. Factory original ones no less, go figure. Anyhow, I have one of the "pickle forks" and I'm having no luck on the lower balljoint. Any suggestions? Wailing on it with a hammer isn't working. It doesn't seem like the pickle fork actually gets "tight", it has stayed easy to wiggle around no matter how hard I hit it.
Help!!!
Old Mar 22, 2002 | 01:57 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Help! Ball joints! (Black68Vette)
Put the bolt on backwards and beat it with a hammer. :smash:
Old Mar 22, 2002 | 02:00 PM
MikeC's Avatar
MikeC
Default Re: Help! Ball joints! (Budman78)
Beat the living snot out of it. It will eventually come loose.
Old Mar 22, 2002 | 02:02 PM
Black68Vette
I already dropped the hammer once on my family jewels :eek: :eek: :crazy: :eek: in the process... Loads of laughs, guess I keep beating away!
Old Mar 22, 2002 | 02:08 PM
70BBvert's Avatar
70BBvert
Try heating up the knuckle also. Use a BFH :) I usually use a 5lb hammer and give it a good wack. Leave the nut on but loose.
Old Mar 22, 2002 | 02:12 PM
vicrattlehead's Avatar
vicrattlehead
I tried popping mine loose last summer to put in new coil springs, and just couldn't get them off. I left them in place, and now I have a full set of Moog's waiting to go on in two weeks (alonf with my now dusty new coil springs from VBP). Please let me know what you did when you get them off. By the way, could you take some pictures of the process along the way and post them? I'd really like to see how someone else makes it work!
Old Mar 22, 2002 | 02:16 PM
Crazyhorse's Avatar
Crazyhorse
Default Re: Help! Ball joints! (70BBvert)
Definitely apply some heat :yesnod:
Old Mar 22, 2002 | 02:26 PM
mayberg's Avatar
mayberg
Pickle fork in an air hammer worked for me, although it wasn't the original and "may" not have been torqued to specs.
What are the torque specs anyway?
Old Mar 22, 2002 | 02:35 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: Help! Ball joints! (mayberg)
:smash: :smash: :smash: Make us proud....
Old Mar 22, 2002 | 03:24 PM
vettedan's Avatar
vettedan
Don't let the ball joints win, I've replaced many and sometimes you really got to hit 'em hard. :boxing
Good luck!
Dan
Old Mar 22, 2002 | 03:28 PM
phoenix's Avatar
phoenix
Default Re: Help! Ball joints! (vettedan)
I just did mine over the last month. I'll post photos when I get home.
Are you sure that you have the right size pickle fork? I got 2, one for the tie rod ends (wider space) and one for the ball joint. I did wail on it for a while too, but it finally gave.
Good luck,
Mike
Old Mar 22, 2002 | 03:44 PM
john's '81 mouse's Avatar
john's '81 mouse
Assuming you have a pickle fork for the ball joints, look to make sure that the inside part of the "U" on the pickle fork isn't hitting on the spindle arm or something else. When I did mine, I found that I had some interference in this area, and I had to grind off some material from the "U" part of the pickle fork, and once I did this, and smacked the crap out of it a few times with a big 5 lb. hammmer (a smaller hammer just won't do the trick), the ball joint popped apart. Good idea to keep the nut loose, but still on by several threads, keeps things from flying all over the place when you do finnally pop the ball joint loose.
Old Mar 22, 2002 | 04:08 PM
Jester69Stingray's Avatar
Jester69Stingray
Default Re: Help! Ball joints! (john's '81 mouse)
I did mine last week. We had to use an air hammer with a pickle fork attachment. It still took forever for the things to come apart.
Old Mar 22, 2002 | 04:33 PM
Black68Vette
Ok, torch, BFH :smash: (8lb sledgehammer) all to no avail over the last 2-3 hours...
What about a pitman arm puller or a tie rod puller? the sorta U shaped ones with the lips, that have a bolt you tighten? anyone tried (successfully) with one of these?
Old Mar 22, 2002 | 04:47 PM
john's '81 mouse
Soak the crap out of it with PB Blaster, and spay two or three times a day and give it a day or two, this may help. Are you really sure that you don't have any interference with the pickle fork which I described above?
I have the tool to remove the ball joints which you've described, but have never used it, since I got mine apart with the pickle fork.
Old Mar 22, 2002 | 04:53 PM
Black68Vette
There might be some interference there, but its pretty hard to see. I know the center of the pickle fork isn't quite hitting the shaft (about 1/4 - 1/2 inch to go) but it seems like it is not sitting "level" on the knuckle. Actualy worth asking, should the wheel be turned to one side or the other or straight?
Old Mar 22, 2002 | 05:21 PM
Jim-K's Avatar
Jim-K
I got mine off easy, use a tie rod end puller. Autozone has one that fits, about 6 or 8 dollars. piece-o-cake. :smash:
To Help! Ball joints!
Old Mar 22, 2002 | 06:38 PM
lyndave75's Avatar
lyndave75
I did mine about a month ago and had some problems with them at first, but then noticed that the forks had spread a bit. I put the fork sideways on the floor, smacked it straight and had much better luck after that. Also found that it helps to get a little angry at them, but you are probably there already!!
Old Mar 22, 2002 | 11:11 PM
Noel Carboni's Avatar
Noel Carboni
Sorry to hear the isn't working. All I can say is keep at it; you'll eventually win.
Bear in mind you could always replace the A-arms. 'Course that means getting the frame bolts loose...
-Noel
Old Mar 23, 2002 | 08:28 AM
Black68Vette
Default Re: Help! Ball joints! (Noel Carboni)
Using a hammer that size, nothing.. using the little tie rod end puller, got one off, and doing the second today (finally). Score Balljoints 1 Eric 1 (cause the first tie rod puller snapped on the second balljoint)
And actually yeah, the control arms are getting replaced, that was the whole point of this painful exercise, installing the VB&P front transverse mono spring. Although actually Noel, I don't see how dropping the control arm first (if I could manage to do it without getting killed by the spring) would help with getting the balljoint shaft out of the knuckle on the spindle
Oh yeah, and everyone, I did realize one thing. My car being a 68 (yay) has the C2 spindles on it (69 started the new spindles). So that may mean that the same tools, etc don't quite fit the same spot. Didn't think of that one till pretty late last nite.
Anyhow thanks everyone! We're almost halfway there now, one control arm off! I took a couple pictures before + during, so when I finally get to the after I will post them :D
