Wheel will not come off !?!
Old Jul 2, 2010 | 09:13 AM
81_vette!'s Avatar
81_vette!
Default Wheel will not come off !?!
So, is my wheel rusted to the rotor... or is there something I am missing?
If rusted... what suggestions do you have in removing the wheel? The other three came off with no issues.
Lug nuts removed - but the aluminum wheel is frozen in place.
Old Jul 2, 2010 | 09:21 AM
SIXFOOTER's Avatar
SIXFOOTER
Its likely just stuck. Sit on the floor next to the wheen and use the bottom of your foot to kick the shyte out of the wheel on one side, then the other, it will pop loose
this assumes you have it safely on a jack/stands
Old Jul 2, 2010 | 10:41 AM
Lee H's Avatar
Lee H
If kicking the tire does not work you could put back on the lug nuts almost all the way on. A few threads out. Then roll the car in the garage or on the driveway, just enough to jar the wheel loss.
Old Jul 2, 2010 | 10:45 AM
75+78 Corvettes's Avatar
75+78 Corvettes
Or with the lugs loosened or off and lower the jack should put enough pressure to break loose the corrosion. typical Aluminum to Steel corrosion.
Old Jul 2, 2010 | 12:16 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
One guy a few years back said he drove his Vette a few miles with no lug nuts, he didn't realize until he got back home. They can get welded on their pretty good
Old Jul 2, 2010 | 12:27 PM
RobRace10's Avatar
RobRace10
I always put anti-seize on the mounting face of aluminum wheels mounted to steel rotors. This makes them much easier to get off if they are on for a few years. Ive had to take sledge hammers to get some wheels off, but I don't advise that.
Old Jul 2, 2010 | 12:29 PM
...Roger...'s Avatar
...Roger...
Thats funny , I have driven with the lugs loose to loosen the wheel.
I usually just pop the center cap and use my torpedo garage heater to free it up.
Old Jul 2, 2010 | 06:45 PM
vettehardt's Avatar
vettehardt
I use a dead blow hammer and hit the rim on the back side. My problem usualy is one hub is a little bit larger than the others and the wheel will stick to that. It's even harder to get my adapters off when they have been on there awhile since it doesn't stick down below the brake rotor. It usually involves big flat blade screwdrivers to get it off.
Old Jul 2, 2010 | 09:44 PM
terry82's Avatar
terry82
i spray wd-40 on the back side of the rim .then i turn away from the car and and kick backwards .i dont no if either way is better but the wheel will come off.get angy with it and don t let your wife take any pics.
Old Jul 2, 2010 | 09:53 PM
noonie's Avatar
noonie
Put all the lug nuts back on and leave them loose about 1/8" from tight.
Lower the car off the jack and rock it side to side.
I always use antiseize on the concentric hub to prevent that.
Old Jul 2, 2010 | 11:41 PM
my 76 ray's Avatar
my 76 ray
Put a couple lug nuts part way on and use a big hammer on the inside of the TIRE.
To Wheel will not come off !?!
