Ball Joint torque spec
Old Mar 23, 2002 | 12:15 AM
mayberg's Avatar
mayberg
Default Ball Joint torque spec
Fellas,
I'm re-installing my Vette Brakes lower ball joint on my 1974 Corvette, and I do not know the torque specification for the large nut on top of the star washer and under the grease fitting in the lower ball joint. I got the Vette Brakes torque specification page in a pdf file, but I interpret the specifications as relating strictly to the 1/2" bolts on the sides of the control arm.
Is there a torque spec for the large nut on the top of the lower ball joint?
Please advise.
Thanks, GM
Old Mar 23, 2002 | 03:19 AM
PatG's Avatar
PatG
Default Re: Ball Joint torque spec (mayberg)
My 79 assembly manual shows 48-60 Newton meters which converts to 35-44 ft-lbs.
Old Mar 25, 2002 | 11:59 AM
mayberg's Avatar
mayberg
Default Re: Ball Joint torque spec (PatG)
FYI - Vette Brakes tech support said about the same thing.
This item is not really clear in service manuals but sense it
is a hollow stud i wouldn't tighten it over 35-45 ft.lb.
To Ball Joint torque spec
