Timing light battery cables not long enough
Old Jul 6, 2010 | 09:17 AM
81_vette!'s Avatar
81_vette!
Default Timing light battery cables not long enough
So, is it OK to hook them up to a separate stand-alone car battery???
or, Can you hook the light up to a set of booster cables in order to reach the battery?
Old Jul 6, 2010 | 09:35 AM
lars's Avatar
lars
Just clip them onto the alternator - red timing light wire to the alternator output post and the black one to the alternator ground lug or case.
Old Jul 6, 2010 | 10:37 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
If you hook it to a separate battery, you will only do it once!
Old Jul 6, 2010 | 10:45 AM
...Roger...'s Avatar
...Roger...
What do you mean by that ?
Old Jul 6, 2010 | 10:11 PM
vettehardt's Avatar
vettehardt
I agree with lars, just hook the red clamp to the bolt being covered by the angled boot and the black clamp to the adjusting bolt on the top of the alternator.
Old Jul 6, 2010 | 10:55 PM
larrywalk's Avatar
larrywalk
It's a shocking development!
Old Jul 6, 2010 | 11:00 PM
...Roger...
Really ? Secondary voltage gets you ?
Old Jul 6, 2010 | 11:13 PM
Vetteran'81's Avatar
Vetteran'81
I've used these retractable test leads for a lot of long range electrical issues, but the alternator trick also works well. I've not used an external battery.
Old Jul 6, 2010 | 11:21 PM
elke_10's Avatar
elke_10
i ran a coil of 12g wire from the terminal like a jumper worked fine for me but my windsheild is out so i went straight threw and not around. i tried the alt to find out i got a faultly output seems someone tried to be the incredible hulk and tighten the nut and it just spins but ya thats another project for me.
Old Jul 6, 2010 | 11:54 PM
another-user's Avatar
another-user
i hook mine up to jumper cables and go right to the battery. hasnt been an issue so far.
Old Jul 7, 2010 | 07:06 AM
JimT's Avatar
JimT
Just use the Alt connector - no need for excess cables draped all over the car, through the windows, under the door, etc.
Old Jul 7, 2010 | 07:39 AM
...Roger...
I agree and less sparks to.
Old Jul 7, 2010 | 07:41 AM
73StreetRace's Avatar
73StreetRace
Where is the problem ?
If you use a separate battery, all you have to do is just to connect its negative terminal to the car ground ( chassis, engine, it doesn't matter ).
You can even use any 12V power supply ( rectified and filtered ) the same way.
Old Jul 7, 2010 | 08:58 AM
rob75383's Avatar
rob75383
I use a spare set of jumpers here. Its how I've done it for over ten years, and it works for me, even if using the alt. is a smarter method. I don't mind the extra cabling, usually when I'm playing with the timing, I've got a mity-vac hooked up to the vac advance, and a vacuum gauge or two connected to the carb/intake - so its already a spider's web of extra hoses. I also like the way the cables are further away from the belts and pulleys.
I keep the jumper cables in an old gym bad to keep 'em clean and roll'd up nicely. I also have an old, broken ice scraper in the bag. I hook up one end of the jumpers to the plastic scraper to keep the leads from touchin, then I hook up the other end to the batt. terminals. I then connect my timing light to the leads on the scraper. No sparks here.
Old Jul 7, 2010 | 05:37 PM
larrywalk's Avatar
larrywalk
And that is the key - if a separate battery is used, that battery must be connected to car ground and you'll be fine. But I answered the question assuming that the separate battery had no connection to anything except the timing light. And if you do that you will probably get a shock from the timing light as it is connected to the spark plug wire. If the timing light is well insulated, you might not, but it is still important that the separate battery is connected to car ground.
Old Jul 7, 2010 | 05:58 PM
...Roger...
Ahhh makes sense now. Just like grabbing a spark plug wire. My old all metal timing light shorted years ago and knocked me for a loop. I've got a plastic one now.
Old Jul 7, 2010 | 09:46 PM
vettes4evr's Avatar
vettes4evr
Just tap the hot lead to your horn relay positive post, just under the d/side fender and connect the ground lead to your alternator bracket.
To Timing light battery cables not long enough
Old Jul 8, 2010 | 02:15 AM
73StreetRace
I absolutely agree !
Old Jul 8, 2010 | 07:10 AM
73jst4fun's Avatar
73jst4fun
that's the easy and best way....
Old Jul 8, 2010 | 09:53 AM
Roco71's Avatar
Roco71
That's how I do it.
