which camshaft
which camshaft
I hear a camshaft is one the most effective upgrades, I found this page at Jeg's for crane, I have no idea what the numbers mean, which one will be best for my 76 L-48 with true dual exhaust, no cats and open air element as the only other mods. is crane the brand to go with the $78 sounds nice, comp cams and lifters are like $220 in ecklers for the L-48...
thanks
thanks
1 Post
Re: which camshaft (szercer)
Do you know what rear gears you have and woud you be willing to use a higher stall converter? Try and stay under 280 actual duration on the street. I had a 280 .480 lift cam with 3.55 gears and a TH350 transmission with a stock converter and it barley squealed the tires. It was a real dog off the line. It would hhave been better with a 260 or 270.
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I recommend the CRANE POWERMAXX Part #113941 Grind # HMV-272-2
454/480 "Lift..... 216/228 * Duration power is 2000 - 4500 rpm and cruise rpm is 2400 Good Idle and Perfomance.
Go to http://www.cranecams.com for more info or other cams. JIM
[Modified by PROSOUTH, 5:37 AM 3/23/2002]
Re: which camshaft (Stingy74)
don't know what rear gears I have, they're stock... not familiar with a stall converter either, this cam has range of 1200-4800 which sounds pretty good for acceleration, what does the cruise range mean?
here's the page for the crane cams
http://www.jegs.com/cgi-bin/ncommerc...371&prmenbr=76
Cruise-In VI Veteran
Cruise-In VII Veteran
You HAVE to replace the lifters if you do the cam. Your old lifters can ruin a new cam in minutes. Also you should use the time to replace the timing gears and chain. The Comp Cam set with everything in it is a good buy, I don't know if Crane has something similar.
