Originally Posted by gerry72
Don't be surprised if it won't idle at all. A four-corner idle has IFRs on both the primary and secondary metering blocks. It also has symetrical IABs at all four corners at the throat entry. A two-corner system has a fuel side only on the primary block. On a two-corner 750-sized carb, you'd be looking at an idle jet around .045 (feeds both primary and secondary throttle plate) which has an area of .0015. If you put a .017 wire (.00022 area) into that restrictor you knock the area down to .00128. Or an equivalent jet of .040 and that's a lot. A four-corner, which you do have, has four IFRs (two in each metering block) in the low to middle 30s, so lets go with a .033 which gives you an area of .009. That .017 wire will reduce your jet area down to .009 which come out to a .011 jet -and that pretty much closes up that hole and if it does, it will pretty much be running off the idle circuit still untouched on the secondary side. And that won't tell you very much other than such an imbalance is not a good tuneup.
Quite true. As I stated earlier, since he has full mixture control over the idle mixture and can kill the engine with the screws, I don't think leaning it out more will solve the rich idle issue - the engine wants what it wants to idle...
I have run wires in the primary side only on a 4-corner carb to get cruise mixture leaned out without affecting WOT. But this is a band-aid fix only to identify a tuning problem.
Originally Posted by Fishndude
IThere is no doubt its fat since I cant even breath, it smells like raw fuel and my eye are watering
Actually, if you go too lean, you'll get random lean misfire, which will drive HC way up, and you can get unburned fuel in the exhaust. Often, if you can "smell" the exhaust, chances are you have high HC from ignition-related issues and unburned fuel from a lean condition - CO (from running rich) is actually odorless. You may have other issues than a rich running idle circuit...
I suppose its possible I could have an ignition related issue (weak coil output).. I installed a new Mallory HEI dist with high output coil last fall and with-in 2 weeks, the coil failed so I replaced it with a new high output Accel coil that fits the Mallory Dist.. If it wasnt a bad coil, its possible the issue that took the first coil out still exists and may have also effected this coil.. I'll do some testing to find out
Drilling the throttle plates is a technique that is used to allow adequate air into the engine to maintain a desired idle speed without opening the throttle blades far enough to expose more than .020" of the transition slots. If more than .020 of the slots is exposed, the engine will run rich due to fuel being discharged from both the idle fuel, transition slots, and in some cases, from the main discharge nozzles. The drilled holes do not lean out the carb by themselves - they allow a smaller throttle opening so the carb can function as it should. Fishndude only has .015" transition slot exposure, so drilling the plates will serve no purpose in his case. Lars
My throttle blades are at the .015 transition slot exposure, because having my throttle blades opened too much, made a off idle stumble I had worse, drilling the holes seems too be the only thing that helped me out of various problems I had, drilling the holes made the idle mixture leaner, but I didnt change the throttle blade exposure, left it at the 015
Any luck yet? I'm interested because I just failed emissions in AZ for high HC at idle (possible lean misfire?). It idles great and pulls strong. I'm running the 750 Holley on a fairly tame 454. Trying to beef up my carb tuning knowledge before I turn the wrong screw...I'm also going to start looking for any vacuum leaks.
Shrekviper
No Luck yet.. I just installed a new Mallory Hyfire multi spark box and it didnt change anything.. I dont thinks its a weak ignition because the car runs strong and pulls hard when I mash the pedal.. BG tech wants to me to try another carb (I have a Holley 650 here) but I just havent had time to swap and try it yet..
Thanks. I'll keep watching, but just found out that I won't need emissions because I have collector's insurance...I'd still like to get mine running like it should. I read Lars' paper and will start tinkering once it cools down a little in AZ.
